need help with charge harness.
Old Jul 19, 2010 | 11:45 AM
k20starion's Avatar
Default need help with charge harness.
ok. i'm doing a k20a3 rsx base swap into my 95 ej1. i've followed hybridracings instruction on making my charge harness. my question is.... what else do i need to do to crank engine over? battery has plenty of juice. engine is grounded. ecu is not hooked up yet.
Old Jul 20, 2010 | 06:39 PM
k20starion's Avatar
Default Re: need help with charge harness.
no one has done a kswap on here?
some one has to be nice enough to share some info.
Old Jul 23, 2010 | 06:34 AM
RenownPer4mance's Avatar
For the K-swap, the battery cable should split. One running to the starter, and one to the fusebox. The alternator main wire should also be going into the fusebox as well. That's pretty much it man as far as power to the car goes.
Monstarrr*
Jul 25, 2010 12:26 PM
xxbvanxx
May 18, 2010 11:25 PM
jdmdohcek98
Appearance Build Threads
Oct 24, 2009 03:52 PM
knightsef-eg
Sep 19, 2008 01:05 PM
EG6owner-T
Jan 4, 2005 03:41 PM
