need help with a harness tuck and misc.!!!
Old Oct 22, 2009 | 09:04 PM
jdmdohcek98's Avatar
Default need help with a harness tuck and misc.!!!
Ok guys im doing a full tuck on my 97 hatch and i have a couple questions. i ran the accesory harness through the fenders and i want to keep my wipers so i want to see how you guys pulled it off? i know i can drill a hole under the wiper motor but then water will get in the cabin.
is there a honda rubber plug grommet to cover the hole by the headlights where the accessory harness used to be to ground the harness?
i decided to keep the battery in the engine bay. i bought a odyssey battery and i want to keep the negative and positive as clean as possible. i ran the starter wire through the harness into the cabin then i made a small unvisible hole to run the starter wire and alse the ground wire (i grounded it inside the cabin). i dont want to run the wire that goes from the fuse to the positive terminal to the battery. anyway to connect it inside the cabin? i was thinking of stripping some insulation from the starter cable and soldering the fuse cable? any other way? maybe distribution box?
sorry for all the long questions or the noobieness but this is my first tuck and i want to do it right. thanks
Old Oct 24, 2009 | 11:45 AM
Default Re: need help with a harness tuck and misc.!!!
nobody?
Old Oct 24, 2009 | 03:52 PM
Ej8_KiD's Avatar
for the wiper wiring i ran man through a hole in the fender , u need to depin de plug in order to do that
b18 type r
Jan 31, 2011 01:29 PM
civics4lyfe
Jan 28, 2009 08:52 AM
one-cam
Nov 12, 2008 01:15 PM
JDM_EK_JOE
Jun 18, 2008 06:37 AM
BLUE EH3
Aug 10, 2004 04:18 PM
