Need help ASAP
Old Sep 22, 2002 | 06:10 PM
sleepercivic's Avatar
Default Need help ASAP
Here are my symptoms
-no VTEC i changed the solinoid and then now it wont werk at all before it was hit and miss and would not work all the time
-Sputtering top end when idown shift into second- this is most likely the plugs as last night it wuold let me go over 4 grand
-Idles bumpy
-MAP is throwing a code and so are my injectors which are wired to a resitor box
this all happened after i turboed
my setup is Hondata stage 3b b16block 9:1 compression 450 DSM injectors
any ideas please help me i need this running so i can race on the 29th!!!
TERRY
Old Sep 22, 2002 | 06:14 PM
Jared's Avatar
Default Re: Need help ASAP (sleepercivic)
fix your wiring. map sensor code = no vtec. lumpy idle is the result of the map code and probably the injector wiring
Old Sep 22, 2002 | 06:55 PM
Default Re: Need help ASAP (Jared)
what could be wrong with the wiring
TERRY
Old Sep 22, 2002 | 07:05 PM
poison's Avatar
the MAP sensor code is the reason you are getting:
lumpy idle, no vtec and sputtering up top end and bogging.
reason for this is because the MAP sensor code is a code that throws the ECU into limp mode.
limp mode, I mean it retards the ignition timing all the way, you run very rich fuel, and fuel cut off varies. I believe around 5500-6000 depening on your ECU. And of course, definitely no VTEC.
Check the wiring to your MAP sensor, as well as vacuum lines, and connections to the throttle body and making sure the MAP sensor can breathe what it needs to be.
Your map sensor is what gives the ecu signal the exact manifold pressure for the right amount of fuel with the air provided for best idle/running quality.
If worse comes to worse, and you know your wiring is fine, as well as your vacuum line, MAP sensor connections to the throttle body is all fine, then replace the MAP sensor.
[Modified by poison, 9:05 PM 9/22/2002]
Old Sep 22, 2002 | 07:20 PM
Default Re: Need help ASAP (poison)
its weird because it was running fine last week and it ran ***** out, then vtec started to not work but not all the time it would work from time to time, the lumpy idle has been there for a while and me and my buddy seem to think it could be the IAC valve is bad?? also i replaced the MAP with my buddies which is brand new so im confused on what it could be, HONDATA, the ECU or is it im limp mode becasue last night it was missing and i think the sputtering top end cuold just be the plugs are fouled?
any one elses thoughts
TERRY
Old Sep 22, 2002 | 07:28 PM
poison's Avatar
Could be IACV. Like I said, man.
Check vacuum hoses, connections and make sure everything is sealed off.
You also might want to replace TB gasket, as well as make sure your MAP sensor is breathing properly what it needs to be.
The connection is on the throttle body.
Old Sep 22, 2002 | 07:42 PM
im planning on swaping a secong gen intake maifold and TB on there and i have a sneaking suspsion it will fix the problem, if not i will try what you said
also if my car werent in limp mode before why would it just snap into it after 3 weeks of runnin
and one more thing where can i find diagrams of all coolant hoses and vacuum line?
TERRY
Old Sep 22, 2002 | 07:44 PM
ohhh yeah and if my injectors were wired wrong would they work at all? what could be making then send a code
and i just remembered yesterday while driving i had a couple times when there were no check engine lights and vtec worked and no sputtering, what could that be
TERRY
Old Sep 22, 2002 | 07:50 PM
poison's Avatar
If your injectors were wired wrong, then they wouldn't work at all.
They only have power signal and ECU signal, that's it.
Checking the proper connections to the MAP sensor will fix the problem
and MAP sensor definitely throws you in limp mode which is the problem you are having.
Old Sep 22, 2002 | 07:55 PM
do you think i should get a gm 3 bar becasue im runnig 9-12 psi?? and im sure the MAP connector is the right one becuase i labled every thing when i took it apart for the turbo
TERRY
Old Sep 22, 2002 | 08:00 PM
poison's Avatar
the GM 3 bar would probalby work with it with running high boost, but can't guarentee it.
I'd definitely look into more research with the GM 3 MAP sensor.
Ask a few people in the FI forum
Old Sep 22, 2002 | 08:12 PM
also one more thing could the bad IAC be causing the MAP, and VTEC and Injectors to throw a code?
TERRY
Old Sep 23, 2002 | 01:36 PM
ANyone know, will a bad IACV make the map throw a code and possibly go bad and the fuel injectors go bad, also what damage can a bad O2 sensor do?
TERRY
Old Sep 23, 2002 | 01:45 PM
Spade's Avatar
A bad O2 will cause your car to run either rich or lean.
I haven't seen an IACV effect other devices yet.
Old Sep 23, 2002 | 01:52 PM
Default Re: Need help ASAP (Spade)
i just know that my IACV has no coolant in it when i took it off or should it not have any?? \
TERRY
Old Sep 23, 2002 | 01:56 PM
could this also have anything to do with the ECU or HONDATA
TERRY
Old Sep 23, 2002 | 05:18 PM
anybody else have any comments on this topic
TERRY
eggie75
Apr 7, 2008 01:40 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
chrysler kid
Sep 28, 2004 07:24 PM
Frosty_spl
Feb 12, 2002 02:06 PM
