need help
Old Aug 7, 2003 | 08:49 AM
LsVtecDA's Avatar
Default need help
ok i just got my ls/vtec motor back together after replaceing my head gasket. when i start the car it idles incredible low and stutters. when it idles low like this i have no CEL. well if i drive the car after about 30 seconds the CEL will come on and the idle will go back to ~1000 and everything will run fine. but the same thing happens everytime i turn the car off and back on. the code its throwing is a Map Sensor code. i dont know what would be causing this, maybe if i didnt hook some vacume lines up correctly or somthing. anyone know what i could check or what would be causing this? thanks in advance.
Old Aug 7, 2003 | 08:51 AM
im sabah's Avatar
Default Re: need help (LsVtecDA)
check for vaccum leaks and your wiring.
Old Aug 7, 2003 | 09:02 AM
mmuller's Avatar
Mad Scientist
Default Re: need help (im sabah)
and of course check the map sensor, your car runs fine after the cel cause it goes in closed loop.
Old Aug 7, 2003 | 03:03 PM
LsVtecDA's Avatar
Default Re: need help (mmuller)
what do i look for with the map sensor? the plug looks fine, what else should i check.
Old Aug 8, 2003 | 09:27 PM
LsVtecDA's Avatar
anyone else know anything that i can check?
D-seriousBis
Apr 11, 2013 05:07 PM
mugencivic94
Oct 26, 2006 10:36 AM
Punker1234
Feb 4, 2006 01:20 PM
AllMotorDA9
Jan 27, 2006 07:48 AM
