help guys!!! quick
Old Jan 9, 2003 | 06:03 PM
89hb's Avatar
Default help guys!!! quick
ok for the last week ive posted question after guestion an ive had some luck but im haveing some more trouble to make a long story short I done a si intake swap,distributor,resistor box , ecu exc.. on my d15 91 crx my ecu is throwing codes it first started with a code 3 which is map sensor well I took the map off my cvic and put it on my crx I thought my problem was fixed I drove it then I threw a code 7 tps sensor so I put another trottle body and sensor on I had lying around and I drove it and still the check engin light came on same thing well today I went to pick up my son from school and when I tried to crank the car it wouldent after several tries I got it started I made it home and now im throwing a code 3 and 7 what the hell is wrong im just about ready to swap every thing back to dpfi if I dont get some help please help me guys! thanx
Old Jan 9, 2003 | 07:20 PM
integra6650's Avatar
Default Re: help guys!!! quick (89hb)
try putting the d15 ecu back in maybe ecu wont work with your sensors
Old Jan 10, 2003 | 02:29 PM
Jaker's Avatar
The Map and the TPS have the same plug. Try swapping around the plugs, you might have them mixed up.
Old Jan 11, 2003 | 01:22 PM
89hb's Avatar
Default Re: help guys!!! quick (Jaker)
theres no way I have the map and tps wrong I never touched the map plug and I had to extend the tps plug wires, im posting qustions but Im not stupid I just thaught other people have had this problem.
95gsrEG
Feb 17, 2009 06:45 AM
luciffer
Oct 4, 2005 05:44 AM
beau_safken
Apr 3, 2003 08:31 PM
89hb
Jan 6, 2003 06:11 AM
.brad
Jan 21, 2002 02:01 PM
