Need help?
I have had an idle issue for a while so i did some searching on here and got as far as figuring it out. The fitv is my problem. I did the "cover the hole in the TB test" and it was sucking air when the motor was completly warm. It was sucking hard too. Im confused as to how you go about getting the fitv to come off. All the searching I did shows people taking it off with there IM off. I just want to tighten the screw inside there and put it back on. It just seems so complicated to get under the TB. If you are trying to tighten the screw wat is the easiest way to start the removal of the fitv???
I see....thats wat i was thinkin about doin. Don't you need to get a new TB gasket then?
More peoples experience are greatly appreciated. C'mon idle people you no wat it was once like!
ITRacer121
11
Mar 25, 2005 01:49 PM
