need code help......cx B16 gsr wiring....
Old Aug 9, 2003 | 02:00 PM
80884's Avatar
Default need code help......cx B16 gsr wiring....
Just swaped the 00 b16a into the 92 cx 94+ gsr wiring. I have a code and the car runs like it has a big cam in it at certian throttle positions. I checked my codes and i have either code 1 or 10 I get one long blink. and thats it. either o2 sensor or IAT. I can see it being the IAT because the plug is not in the same place as the b16a wiring was. What two wires should be going to this IAT sensor when using the gsr wiring i the 92 cx with the 00 B16? Please help!
Also i was told i did not need to run wires for the 4 wire o2 sensor that they are already in the car in 92. car runs the same with the O2 sensor plugged in or not.
Old Aug 9, 2003 | 05:36 PM
80884's Avatar
Default Re: need code help......cx B16 gsr wiring.... (80884)
So i'm the only one on ht that has done this swap? help please.
Old Aug 9, 2003 | 11:35 PM
salbaje's Avatar
so you have a 2000 si motor and you are using a 94-95 obd1 gsr wiring. Your car is only prewired for vtec if its a 92 model. try wiring up the 4 wire 02 coz your cx only had 1 wire o2
Old Aug 10, 2003 | 08:22 AM
80884's Avatar
Default Re: need code help......cx B16 gsr wiring.... (salbaje)
So the car is prewired for VTEC only, and not the 4 wire o2 sensor? That would make sence but i was told it was prewired for both. hmm. ok
DABBY
11
Apr 12, 2019 12:09 PM
blazinrola80
Jan 6, 2008 10:09 AM
Mike D
Apr 1, 2004 11:33 AM
