n00b question about engines Need help asap
Old May 26, 2003 | 10:30 AM
mYsTeR2's Avatar
Default n00b question about engines Need help asap
What exactly is a longblock? Is a longblock a whole engine? If not what else is needed for it to be swaped in? Thanks.
Old May 26, 2003 | 10:43 AM
agturbo's Avatar
Default Re: n00b question about engines Need help asap (mYsTeR2)
Yes it is the whole engine, the head and bottom end
Old May 26, 2003 | 10:45 AM
Flexmyrex's Avatar
a long block consists of the head and the block. some distributors will include the exhaust and intake manifolds, alternator, distributor etc even though they can charge you extra for each part . you will also need a transmission, axles, intermediate shaft, rear mount bracket ecu and maybe after market mounts depending on the type of car you have
search around and you;ll find out more
Old May 26, 2003 | 10:46 AM
MikeSarr_GSR's Avatar
longblock would be considered the head and block with everything inside.
if bought new from honda you would get:
head, headgasket, no valvecover
cams, cogs, valvetrain, no manifolds
water pump, no waterpump housing or waterpipe
no belts, no hoses
block
oil pan/gasket
no sensors
no distributor
if you get it from somone else, I wouldnt count on manifolds
but everything from the valvecover to the oilpan. when I sold
my old GSR longblock I reused my waterpipe, sensors and
valvecover, distributor so it sold as is.
Old May 26, 2003 | 11:58 AM
mYsTeR2's Avatar
Default Re: n00b question about engines Need help asap (MikeSarr_GSR)
Thanks guys
junior40er
24
Jun 21, 2006 10:52 AM
Brain3208
Mar 7, 2006 05:48 PM
tempuus
Nov 28, 2005 07:16 PM
prelude122
Jul 23, 2004 02:21 PM
Skunk2Civic94
Mar 26, 2003 03:18 PM
