my transmission case is broken
Old Dec 20, 2004 | 02:33 PM
(Civic_Duty)'s Avatar
Default my transmission case is broken
ok
my transmission case is broken where the mount bolts on it the tranny (car was wreacked) what do i do ?
if i replace the case; what cases can i use? (i am in hickville ark not of alot of honda in dat dar bone yard)
if i can not find a case local which is cheaper
1: new tranny (used)
2: New case
3: weld it up
4: sell my m0m and save up for a itr tranny
Old Dec 20, 2004 | 03:08 PM
grndcont's Avatar
jb weld baby!
j/k you better buy a new case.
Old Dec 20, 2004 | 03:20 PM
Default Re: (grndcont)
where can i get 1 and how much they run?
can i just weld the blots back in the tranny?
Old Dec 20, 2004 | 03:23 PM
Dragline's Avatar
Default Re: my transmission case is broken (tweakedcrx)
It 's A cable trans right?
I'll sell you a case.
Old Dec 20, 2004 | 04:32 PM
Default Re: my transmission case is broken (dragline)
hydro
Old Dec 20, 2004 | 05:07 PM
Dragline's Avatar
I got one of those to.
Old Dec 20, 2004 | 05:15 PM
??? u got 1 for sale?
Old Dec 20, 2004 | 05:32 PM
86si's Avatar
get a new one they aren't much
Old Dec 20, 2004 | 09:36 PM
PrettyLude's Avatar
Default Re: my transmission case is broken (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">get a new one they aren't much</TD></TR></TABLE>
Old Dec 20, 2004 | 11:15 PM
Default Re: my transmission case is broken (PrettyLude)
Lafayette in da house
how much is not to much?
Old Dec 20, 2004 | 11:35 PM
see where the 2 bolts go
Old Dec 21, 2004 | 12:03 AM
PrettyLude's Avatar
check it out at http://www.hondaautomotiveparts.com
Old Jun 16, 2010 | 04:40 PM
joe Dailey's Avatar
mine too. My 2006 was wrecked prior to my ownership. I got my oil changed and my mechanic told me my transmission case was broken and needed a new transmission. Talked to Honda America and they said because the car was wrecked all warranties all canceled. However my mechanic says he has never ever seen this happen to a transmission. He searched a few junkyards and could not find any transmissions. He said that was odd for a 2006 model. There should be transmissions available, Why not? Too many other Honda cracked transmission problems????
Old Jun 16, 2010 | 06:03 PM
fcm's Avatar
fcm
Old Fart
The GSR transmission in my 94 LS was from a wrecked GSR, cracked at motor mount, [7" long.
I pulled the transmission apart, did a little hammering to close up the crack and had it welded on the inside and out, used a grinder to smooth out the bead on the inside, [where it was in the way] and the same on the out side.
No problems with it for the last 7 years, been auto-crossed for 5 of those and the tranny has been pulled 5-6 times to replace springs on the Phantom Grip LSD, but tranny has been good. 94
eg grom
Sep 1, 2009 08:50 AM
jr408
Feb 25, 2008 08:34 PM
Pete_SI
18
Jul 28, 2005 05:47 AM
cozmo2312
10
Jan 15, 2004 06:22 PM
oem
Nov 27, 2003 08:04 PM
