my R block has arrived
the motor is finished, i currently have 350 miles on it. runs strong...although i will be getting hondata as soon as i can afford it, which should be in 3-4 weeks. i will post pictures soon...i have just been busy with finals...etc...
was finished about a week ago now...and i've only driven 350 miles...kinda lame...but i really have been busy.
setup:
Brand New ITR Head
Brand New ITR Bottom End
Head Shaved 20k
OEM Headgasket
P30 Intake Manifold
P30 TB
Hondata Intake Manifold Gasket
Comptech ITR Header
Test Pipe
Apexi World Sport
JDM ITR Transmission (4.785 FD)
Brand New ITR Head
Head Shaved 20k
OEM Headgasket
P30 Intake Manifold
P30 TB
Comptech ITR Header
Test Pipe
Apexi World Sport
nice setup y0! are you getting this beast tuned at secret? more than likely I may be coming out to check out that shop when my boy's Turbo R is getting tuned.
Sometime this month... so. Yea that EG will be honda challenge material no doubt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR »</TD></TR><TR><TD CLASS="quote">nice setup y0! are you getting this beast tuned at secret? more than likely I may be coming out to check out that shop when my boy's Turbo R is getting tuned.
Sometime this month... so. Yea that EG will be honda challenge material no doubt.</TD></TR></TABLE>
I higly recommand them if you in the area, however, do call in advance to set-up with an appointment.
Secret Services
727-571-1450 or email at vapor1@tampabay.rr.com
Also, Mastro Subaru has a 4-wheel dyno for your 4WD motor heads as well.
Secret Services
NA 215 SAE corrected whp would be attainable with full tuning and a
bad *** header. I estimate chet even with B16 cams will pull in the
high 170s to low 180s corrected untuned
unless he dropped
for the R cams also... hmm
Thats just a solid street/strip estimate.
If he wanted to make it a trailer queen and bump compression to the moon,
230-270 at the wheels 2.0L and 13-15:1 CR w/ITBs and equal length headers
and full tuning...
the limit is your knowledge and what you have available to you/money this
motor is nasty for a stock honda setup.
unless he droppedfor the R cams also... hmm
Thats just a solid street/strip estimate.If he wanted to make it a trailer queen and bump compression to the moon,
and full tuning...
mike, i did get a brand new ITR head as well...
i'm just using a p30 intake manifold and TB.
i want 200whp with the p30 intake manifold, and i'm using a comptech header so i think i can get at least 190...
first i need cam gears, then hondata...then i'll dyno it.
Nice, basically the same route I went. ITR bottom-end from Acura
Be careful if you mill the head if your still gonna jump to cams later. Talk to the cam suppler about how much to mill.
Anyway, nice set-up, good luck
i already milled the head so its already something i have to consider.
i'm thinking about trying spoon cams...but i may just stay with the R's if i get the power i want after dynoing.
otakueric
28
Feb 27, 2004 01:02 PM
nice.
