are my pistons supposed to wiggle?
Old Dec 8, 2003 | 02:32 PM
Kimo's Avatar
Default are my pistons supposed to wiggle?
ok i have a 92 honda civic hatch, with a d16y7 motor and turbo boosting 9 psi-- i blew my headgasket-- but the motor still ran pretty normal, just had smoke coming out of the valve cover-- or when u took the oil cap off-- so i toook off the head and i can wiggle the pistons alittle bit-- all of them all 4- is that bad????
Old Dec 8, 2003 | 03:13 PM
Kimo's Avatar
Default Re: are my pistons supposed to wiggle? (Kimo)
?? anybody
Old Dec 8, 2003 | 03:44 PM
mattssi's Avatar
I dont think that you should be able to wiggle them, do you mean back and forth?? Possibly your rings are bad? Too bad you already took off the head, could have done a comp test!
Old Dec 8, 2003 | 08:31 PM
Kimo's Avatar
well my head gasket was blown so i think the compression was low already--
like i said i was driving it around for the last few days and it ran fine-- just leaking oil everywhere-- also there was detonation some times-- i dont know-- i dont want to put the head back on if the piston rings are messed up
Old Dec 8, 2003 | 08:34 PM
Kimo's Avatar
yeah back and forth- not up and down hehe
Old Dec 8, 2003 | 08:49 PM
ShowSi2's Avatar
pistons aren't perfectly round they are shaped like and oval, but barely noticable unless ur using measuring tools, but you shouldn't be able to wabble the piston with the rings on it so most likely ur gonna need new rings in the near future
Old Dec 8, 2003 | 09:04 PM
Kimo's Avatar
Default Re: are my pistons supposed to wiggle? (ShowSi2)
k new question-- should i go ahead and put the head and new head gasket back on? and drive it- or just ditch the block??
because there is a guy selling another block with head studs and block gaurd for 100 bucks- what u think??
Old Dec 8, 2003 | 09:23 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kimo &raquo;</TD></TR><TR><TD CLASS="quote">k new question-- should i go ahead and put the head and new head gasket back on? and drive it- or just ditch the block??
because there is a guy selling another block with head studs and block gaurd for 100 bucks- what u think??</TD></TR></TABLE>
For 100 bucks yeah just make sure the block gaurd was intalled correctly (not tapped in with a hammer) i would say use that and build the block you got now
Old Dec 9, 2003 | 07:14 AM
Kimo's Avatar
Default Re: are my pistons supposed to wiggle? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
For 100 bucks yeah just make sure the block gaurd was intalled correctly (not tapped in with a hammer) i would say use that and build the block you got now </TD></TR></TABLE>
yeah thats pretty much what im thinking-- then i can boost alittle higher thanks man.. peace
dapaur
Apr 9, 2008 06:04 AM
allmotorgsrekk
Jul 31, 2006 05:13 PM
4gencivicef9
Jun 27, 2006 05:51 PM
oilguzzler
Mar 14, 2006 09:13 AM
lude019
Feb 9, 2003 11:20 PM
