Is my flywheel D.O.A.?
Old Nov 10, 2002 | 06:55 PM
Batoutahell's Avatar
Default Is my flywheel D.O.A.?
Sorry for the pic size, I'm not very skilled with posting pics. I dropped the tranny of my beater this weekend ('85 mr2) and found a mess. One of the springs on the clutch disk had disintegrated. I bought the car used a few months ago with 140,000 miles, and I have every reason to believe it's the original clutch, pressure plate, flywheel, etc. Can I have some opinions on whether the flywheel is in "ok" shape to re-use. Possibly if I get it resurfaced at a machine shop? Pic is below.
Also, how do I tell if the pressure plate is serviceable? None of the fingers are broken. Is there a wear pattern I should look out for, or "springiness"? Also, what signs of wear should I look for in the throw out bearing?
Since this is my beater, I'd like to get away with buying a new clutch plate and re-using the rest of the parts if I can. I can't imagine the car will last more than another 30-50,000 miles anyway, so cheap is the word. Thanks for your help!
Old Nov 10, 2002 | 07:15 PM
raene's Avatar
Default Re: Is my flywheel D.O.A.? (Batoutahell)
The flywheel doesn't look that bad, just get it resurfaced. Mine doesn't look much worse than yours, IMO. Also, I wouldn't re-use the PP... you'll end up prematurely having to remove your tranny and replace the clutch again. Compare the time you'd waste re-doing it vs. the cost of doing it right the 1st time... time is money
Old Nov 10, 2002 | 07:37 PM
Kamin's Avatar
hell no
that flywheel is fine
you should see the one on my origional d16 motor.
just get it resurfaced and your good to go.
Old Nov 10, 2002 | 08:39 PM
Default Re: Is my flywheel D.O.A.? (KAMiN)
Off to the machine shop. Thanks guys.
blazin99si
Transmission & Drivetrain
May 30, 2012 07:53 PM
h8ted ek
Dec 22, 2006 07:41 PM
methanemotorworks
Feb 13, 2006 07:32 PM
Overblown-Teg
Apr 22, 2005 11:18 AM
Corinthians
Sep 28, 2004 11:46 AM
