Clutch issue
Old Apr 14, 2005 | 11:30 AM
Overblown-Teg's Avatar
Default Clutch issue
Anyone ever see a clutch grind out the pressure plate and flywheel like this?
Old Apr 14, 2005 | 11:34 AM
s2kdre's Avatar
Default Re: Clutch issue (Overblown-Teg)
pics dont work
Old Apr 14, 2005 | 11:35 AM
Default Re: Clutch issue (jdmhonda)
it is hosted on image venue and it appears when I close that window the pic goes away.. hmm..
Old Apr 14, 2005 | 12:49 PM
Old Apr 14, 2005 | 01:04 PM
EJ1 wilcox's Avatar
Whoa...
It's kinda hard to see in the pic, but it looks like the pp and flywheel wore down but the clutch dish didn't! LoL... what's that disk made out of?
Old Apr 14, 2005 | 01:55 PM
FORCEDFEDTEG's Avatar
My 6 puck clutch did the same thing. Ate up the flywheel and pressure plate with little wear to the disc.
Old Apr 14, 2005 | 02:01 PM
DRAGLS's Avatar
Default Re: Clutch issue (FORCEDFEDTEG)
its the ceramic material used on the disc
Old Apr 14, 2005 | 03:56 PM
rhd's Avatar
rhd
spec, by chance todd?
Old Apr 15, 2005 | 05:52 AM
Default Re: (rhd)
Yes it is Spec and your right the disc is like new yet will barely engage do to the destruction of the flywheel and pressure plate, This was suppose to be a street disc, That is after 25,000 miles of street driving. They are not standing behind it at all. They claim I must have a defective factory flywheel. I don't know what the deal is with the hosting but I have a bunch of pictures, some show it better than others.
I want to post them all as a warning to not buy from them. Or atleast know what your getting a head of time.
Old Apr 15, 2005 | 06:27 AM
92civicb18b1's Avatar
damn...
at least you really don't need a new disc.
Old Apr 15, 2005 | 06:31 AM
evosol's Avatar
Default Re: (92civicb18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 &raquo;</TD></TR><TR><TD CLASS="quote">
well... its not the clutch/disk's fault, the just the nature of the disk. buy a new one, don't cry about it.
Old Apr 15, 2005 | 06:32 AM
yeah it sucks.. If this is considered normal wear then that is fine, but I was told this was a street disc, It is assumed it would last like a normal street clutch, If I would have known I would get a year and a half out of it then I never would have bought it. It's not like it was cheap, I think I paid over $400 for it and now I need a new flywheel $250 and a new clutch, I'm running a stage 2 this time.
they told me they sell hundreds of these and I am the first one to have this problem. Does anyone else have a similar problem with the stage 3 clutches?
Old Apr 15, 2005 | 06:50 AM
twkdCD595's Avatar
Default Re: (Overblown-Teg)
hope mine does not turn out the same way (just finishing the break in)... although from the look of the pic, I am running a different 6 puck disc with my stage 3.
Old Apr 15, 2005 | 07:23 AM
Default Re: (evosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evosol &raquo;</TD></TR><TR><TD CLASS="quote">
The only reason I am not happy is I wasn't told it would last this long, if I had been it would be no big deal. I would not have bought it. I was told by Spec that for a street car this was the disc I wanted. They said nothing about premature wear or killing the other parts. Had they I would have gone with a normal disc.
Old Apr 15, 2005 | 09:30 AM
twkdCD595's Avatar
I would be a bit mad too if they told me that was the recommended disc to use and then this... call them up and ask about it, and they blow you off saying it must have been your flywheel... bahhhh sounds like weak manufacturer bs, they dont like to make anything easy.
You need some CSI **** to prove what the really happened to clutch in question... anyone got a friend or something?
Old Apr 22, 2005 | 11:18 AM
95GSRTT
Guest
Posts: n/a
Default Re: (twkdCD595)
i had the same thing happen to my RPS. The disc completely ate away the PP and the flywheel, so i have to get a whole new assembly. Except Im pretty sure it was the flywheel being warped.
Ill be giving RPS another chance and going with a segmented heat shield on my PP just incase. Hopefully it all works out.
94DB8
Feb 1, 2008 07:55 AM
h8ted ek
Dec 22, 2006 07:41 PM
95LssTeg
May 12, 2006 12:16 PM
methanemotorworks
Feb 13, 2006 07:32 PM
DPSJosh
Aug 26, 2005 06:09 AM
