Dyno Plot from today's tuning
Old Mar 6, 2003 | 05:39 PM
blu_si's Avatar
Default Dyno Plot from today's tuning
Here's what my car did at the dyno today. Sorry i gotta run, but i thought you guys might like to see what i put down. If you've got questions you can leave em on the thread or pm me. Laters
Old Mar 6, 2003 | 05:41 PM
-iLLuZioN-B18C1's Avatar
Default Re: Dyno Plot from today's tuning (blu_si)
whats the set up?
nice numbers!
Old Mar 6, 2003 | 05:54 PM
done's Avatar
Default Re: Dyno Plot from today's tuning (jvithayapun)
such high hp, seems like a low tq...
i guess for a b16 not to bad..
is that vortech supercharger dyno??
Old Mar 6, 2003 | 06:07 PM
blu_si's Avatar
such high hp, seems like a low tq...i guess for a b16 not to bad..
nope it's turbo for sure.
whats the set up?
nice numbers!
b16 (forged pistons and rods)
drag kit (swapped in a precision turbine .48/.60)
550cc injectors
2.5"dp flared to 3" the rest of the way out
Hondata 2b
Old Mar 6, 2003 | 06:11 PM
Midwestrider's Avatar
I know the turbo is a Precision.
ekb18c's Avatar
how many psi?
Old Mar 6, 2003 | 06:14 PM
The_Head's Avatar
Default Re: Dyno Plot from today's tuning (ekb18c)
I'm gonna guess thats 14.7 psi...
Did I win?
Old Mar 6, 2003 | 06:17 PM
blu_si's Avatar
that was at 14.7psi
Old Mar 6, 2003 | 06:18 PM
blu_si's Avatar
Default Re: Dyno Plot from today's tuning (xThexHeadx)
Did I win?
yes you did
Old Mar 6, 2003 | 06:19 PM
The_Head's Avatar
Awesome! I won!
Old Mar 6, 2003 | 07:15 PM
inspyral's Avatar
Nice numbers
What's with that dip in the powerband? Is that from VTEC engaging?
Old Mar 6, 2003 | 07:42 PM
keebler65's Avatar
Default Re: Dyno Plot from today's tuning (inspyral)
yeah it looks like it was probably engaged too early or it hasnt been tuned 'perfectly' yet. nice improvement in numbers though
post some pics!!!
Old Mar 6, 2003 | 08:07 PM
SiRkid's Avatar
Default Re: Dyno Plot from today's tuning (keebler65)
nice numbers..quick spooling turbo
Old Mar 6, 2003 | 09:42 PM
blu_si's Avatar
Yeah i'm not sure what that dip is, but it seems to happen right where vtec kicks in. Not sure why though maybe someone could help me shed some light on that.
Old Mar 6, 2003 | 10:04 PM
TurbothisLS's Avatar
how much boost
Old Mar 6, 2003 | 10:08 PM
R-1303's Avatar
the dip is from the cam switching over, it is overlapping so u get a slight dip..no problems just more tunning and you'll get a smooth curve. Nice #'s
Old Mar 6, 2003 | 11:08 PM
blu_si's Avatar
Default Re: Dyno Plot from today's tuning (R-1303)
would some cam gears help smooth out the curve? i plan on puttin in some gsr's and cam gears in the next couple weeks.
Old Mar 7, 2003 | 07:47 AM
RAWB's Avatar
How's your A/F? Some guys run a bit lean when their VTEC engages and causes a power dip like that. Good numbers, btw
Old Mar 7, 2003 | 08:21 AM
blu_si's Avatar
Default Re: Dyno Plot from today's tuning (RAWB)
at particular poin my a/f was about 12.7-13.0
Old Mar 7, 2003 | 06:03 PM
hatchy's Avatar
Why does it say MAX HP = 301 when the graph shows ~315ish?
Old Mar 7, 2003 | 07:02 PM
inspyral's Avatar
Default Re: Dyno Plot from today's tuning (hatchy)
I think you're looking at the torque curve. If you look at the scale ont he right, that curve lines up with about 215, which is what his max torque is.
Old Mar 7, 2003 | 07:31 PM
blu_si's Avatar
i have no idea, damn computers
Old Mar 7, 2003 | 08:02 PM
b16ahybrid's Avatar
Try moving the vtec switchover up in a little.
I had my vtec switchover point at 5,200rpm and there was a dip that looked like yours. I was losing 20whp at that point. I moved the vtec point up to 6k rpm and the transition is a lot smoother. I only lose about 3 whp now when it switches over.
6k is a bit high but it works the best for me. The guy who dyno'd my car said that it's a common trait that turbo charged vtec honda's have.
Old Mar 8, 2003 | 10:01 AM
BoostedED9's Avatar
Default Re: Dyno Plot from today's tuning (b16ahybrid)
i make 302hp and 251tq with a sohc on stock internals... looks like you need to do some more work..
Old Mar 8, 2003 | 11:01 AM
blu_si's Avatar
Default Re: Dyno Plot from today's tuning (BoostedED9)
well, my compression is a lot lower than yours is, i'm sure. so, if by work you mean increase displacement and compression than sure, that is my next project. Also, how long do you think your stock internals will last? Cause i know my internals will hold up to that amount of power for quite some time. How often to run at that much boost anyway? daily or was that just your peak hp numbers?
