my car is overheating and dont know why
Old May 5, 2002 | 09:10 PM
civicR1's Avatar
Default my car is overheating and dont know why
ok.. ever since i installed the skunk2 intake manifold my car was overheating...
not sure if thats the reason or not but i need to resolve this problem.
i bleed the system so many times... my car is really lean because of my stock ex pump that im going to replace this weekend.
can it overheat from running to lean?
when i take off the thermostat everthing is fine... on the hwy it runs way to cold..
have a spoon thermostat.
please can some one help me ?
Old May 5, 2002 | 09:22 PM
-=TWITCH=-'s Avatar
Default Re: my car is overheating and dont know why (civicR1)
get a stock thermo junk the spoon
Old May 5, 2002 | 09:25 PM
civicR1's Avatar
Default Re: my car is overheating and dont know why (-=TWITCH=-)
the spoon thermo is brand new... would that be the reason for overheating?
Old May 5, 2002 | 10:08 PM
civicR1's Avatar
anybody can help me? i know by changing the thermostat to stock won't help right?
Old May 5, 2002 | 10:35 PM
MrFatBooty's Avatar
I'd say the lean condition is your problem. Running lean makes more heat, simple as that.
Old May 6, 2002 | 07:04 AM
88_SC_CRX_Si's Avatar
New User
Those tiny bubbles, might just be a clue to a bad head gasket. Mine did something like that, last time it blew. Had to wait 20+ minutes before any bubbles showed up in mine. hehehe
About the only thing you can do, is have a "Leak Down Test" done on it. That will tell you a lot more then a compression test will....
Old May 6, 2002 | 07:46 AM
rainforest's Avatar
Default Re: my car is overheating and dont know why (88_SC_CRX_Si)
oh god guys relax its just air bubbles. fill the car with coolent and run the motor so the fan turns on twice while leaving the radiator cap off. and i garentee it will stop. or there could be one oter thing. you forgot to connect one of the coolent lines and it is just leaking.
96_RHD_EK
Apr 10, 2008 06:44 AM
JDMJAYDC2
Apr 23, 2007 08:44 AM
I got a honda
19
Dec 11, 2005 05:32 PM
kleefton
Mar 21, 2005 07:37 PM
IN VTEC
Oct 27, 2002 01:13 AM
