my b20 idles real high
Old Feb 1, 2010 | 12:44 PM
b20vtec turbo's Avatar
Default my b20 idles real high
ok my b20 vtec turbo idles at bout 3000 rpm when it warms up it idles at 2400 does anyone know what it could the car was sitting for bout 1 month before it started this problem no check engine light either
Old Feb 1, 2010 | 02:03 PM
mouab18c1's Avatar
Default Re: my b20 idles real high
any vacuum leaks?
Old Feb 1, 2010 | 07:47 PM
no vaccum leaks what happened was i shipped my car to hawaii before i did that it was running fine then i got it in hawaii a month later its idle high but there are no vaccum leaks i so stumped on it
Old Feb 2, 2010 | 11:50 AM
mouab18c1's Avatar
try cleaning your IACV
Old Feb 2, 2010 | 06:34 PM
i already tried that to
Old Feb 3, 2010 | 10:16 AM
mouab18c1's Avatar
well then check to see if your throttle cable is stuck, try adjusting your tb screw, look for any coolant leaking, and if you havent then re bleed your coolant system
Old Feb 3, 2010 | 12:54 PM
it idles at 1400 with out the radiotar in and i unhooked the throttle cable idk this is really ignoing
Old Feb 3, 2010 | 02:24 PM
mouab18c1's Avatar
you start your car without the radiator? kinda crazy, is this a half size or full size radiator. maybe dramatic temperature differences can be the problem?
Old Feb 16, 2010 | 06:49 PM
but it never did that until i let it sit for bout 6 months before that it idle fine
skerrttt
Apr 26, 2013 07:19 PM
hybrid21
Nov 28, 2009 03:06 PM
aftershock2686
May 8, 2008 05:25 PM
ECICivic
Mar 16, 2005 10:46 AM
1hottEG6
Dec 19, 2001 07:58 PM
