b20 idle problem
Old May 7, 2008 | 11:26 AM
aftershock2686's Avatar
Default b20 idle problem
ok i swapped a b20 in my teg and my idle is around 1300 rms and i cleaned the iacv and it worked for like 1 day and its at 1300 rpms again im getting a used iacv of a friends motor that i know works, idk wut else it could be and suggestions would be helpful
Old May 7, 2008 | 01:48 PM
lovemyDC2's Avatar
idle screw on the intake manifold???
Old May 7, 2008 | 02:17 PM
ivan93egreppin210's Avatar
Default Re: (lovemyDC2)
are all you coolant bypass hoses connected? the guy who had my car before me did "the coolant bypass removal trick" it screwed my idle up. once i put it back my car ran good again.
Old May 7, 2008 | 05:27 PM
there is one and i have no idea where it goes its right under the throttle body,
Old May 8, 2008 | 08:09 AM
Old May 8, 2008 | 09:07 AM
Default Re: (aftershock2686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aftershock2686 &raquo;</TD></TR><TR><TD CLASS="quote">there is one and i have no idea where it goes its right under the throttle body, </TD></TR></TABLE>what are you talking about? hose or screw?
Old May 8, 2008 | 05:25 PM
its a hose
EJ1A1
Jan 6, 2017 12:07 PM
Scott Little
Nov 12, 2015 01:06 PM
Rob!
Mar 18, 2004 02:46 PM
1hottEG6
Dec 19, 2001 07:58 PM
