motor swap Q!
Old Apr 29, 2003 | 05:43 PM
RabbittZ's Avatar
Default motor swap Q!
ok.. problem came up. i know the GSR motor is a straight bolt in for an EG. but what about a/c brackets... are they the same? will the bolt in easy with no big changes of lines. and overall.. will it fit in my 95 cx? thanks for helping and if you can throw anything as of advise... let me know. thanks
Old Apr 29, 2003 | 06:57 PM
untitled's Avatar
Default Re: motor swap Q! (RabbittZ)
whoa there, the usdm gsr is a direct bolt in swap. the jdm isnt. and ac should bolt in since it is essentially the saem chassis.
Old Apr 29, 2003 | 08:16 PM
RabbittZ's Avatar
Default Re: motor swap Q! (88crx91integra)
LOL.. sorry.. yeah i meant the usdm motor. so it will just connect like normal civic a/c????
Old Apr 29, 2003 | 08:52 PM
tilt's Avatar
first time ive heard this. can you explain why? thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">whoa there, the usdm gsr is a direct bolt in swap. the jdm isnt. and ac should bolt in since it is essentially the saem chassis.</TD></TR></TABLE>
Old Apr 29, 2003 | 09:55 PM
RangerDan's Avatar
Default Re: motor swap Q! (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">first time ive heard this. can you explain why? thx
JDM Type R motors are NOT the same in terms of using the engine harness, etc.
For a JDM ITR swap you will need to use the stock Civic engine harness, injectors, and either an OBD1 DOHC VTEC distributor or re-pin the JDM ITR one.
ECU? If you plan on using the JDM ITR P73 ECU, you'll need a jumper harness since it has the OBD2 plug style, BUT even though the plug style is OBD2, the ECU is indeed OBD1. I had a 1996-spec JDM P73 ECU and I assure you it was an OBD1 program with OBD2 plugs.
I am not sure if or even when the JDM ITRs went OBD2, but I *think* it may have been as late as 1999 when the ECU plugs changed again like they did here in the U.S. One thing is certain: the 1996-spec ITR is OBD1 even though the plug is OBD2.
If you plan on using a re-chipped P28 ECU, then you will need to add a VTEC oilpressure switch onto the ITR motor. JDM ITR motors do not have the VTEC Oil switch, and the P73 ECU does not look for one, but the USDM P28 ECU DOES look for the VTEC Oil switch. VTEC will not work if you don't add this switch. Any switch from any VTEC motor should work - USDM D16Z6 (1992-1995 Si/EX; Del Sol Si), B18C1 GS-R, B16A, etc. so put it on and go.
That's about all I can think of for the JDM ITR swap. Anybody that knows for sure the OBD1 cut-off in Japan please feel free to post it.
I do know that the JDM ECU sucks *** because of the speed limiter
B18C5-EH2 wrote this on a different post.
On the 5th gen Civic you need a delsol si bracket for the a/c unit.
Old Apr 29, 2003 | 10:08 PM
tilt's Avatar
Default Re: motor swap Q! (RangerDan)
When you said its not a direct bolt in swap, I thought you were indicating the engine mounts werent the same for the jdm gsr. thx for the itr info though.
Old Apr 29, 2003 | 10:59 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan &raquo;</TD></TR><TR><TD CLASS="quote">
Anybody that knows for sure the OBD1 cut-off in Japan please feel free to post it.</TD></TR></TABLE>
Plug styles stayed the same as USDM. Programming stayed OBD1.
So from what I've gathered over a long time reading on tech sites:
96-99 = OBD2a plugs
00-01 = OBD2b plugs
(for all integras in all countries)
But I've never seen a JDM ecu from a 00-01 and compared it with 96-99.. so I'm not 100% sure.
Old Apr 30, 2003 | 10:38 AM
RabbittZ's Avatar
Default Re: motor swap Q! (Nameless EJ6)
ok thanks for all that info on the motor.. but what about my a/c question? for a usdm motor and my civic cx hatch? *begs* dont high jack my post!!!
Old Apr 30, 2003 | 10:44 AM
94CivicSi's Avatar
Integras come with the P72 AC bracket wich WILL NOT accept the Civic's AC compressor. You can gt 1 or 2 of the 4 bolts in, but they will eventually break. You need the Del Sol P54 bracket.
Old May 1, 2003 | 09:03 PM
RabbittZ's Avatar
Default Re: motor swap Q! (94CivicSi)
with the del sol bracket.. does that mean that i have to do some welding???
Old May 1, 2003 | 10:47 PM
RangerDan's Avatar
nope...did you contact that importer?
Old May 2, 2003 | 06:04 AM
RabbittZ's Avatar
nah..i think im just going to look around before i order anything from afar... but yeah.. i guess i just need to under the hood and see what this bracket looks like.. you say use the del sol bracket.. why not the Teg bracket?
BIG T
14
Feb 19, 2008 08:04 AM
odd22004
Oct 21, 2007 02:28 AM
DarkBB4
Aug 31, 2004 07:17 PM
RudeLude
Jan 3, 2004 12:49 AM
xkhalil333x
Dec 24, 2003 12:49 PM
