motor smoking, not a normal question
Setup: ITR swap, ported head i/h/e Z10 catch can (from hi-comp days) 9100 miles on rebuilt setup
About three days ago my car started smoking at idle a bit, so I figure the catch can is full and I dump it. It was full. Well the smoking didn't stop, it progressively got worse. It smokes when Idleing and when I first take off but after that it stops (or seems to). The only way to make it stop is WOT. Today I pulled the plugs and did a compression check. 210 across the board. So then I crank the car and pull the plug wires one by one to see if I can make it stop smoking to pinpoint the problem cylinder. No such luck. It still smoked the whole time. I took the filter off of the catch can to feel if any air was coming from the can. It was barely enough to feel if any. Has anyone experienced this?
DoHcZC91si
Aug 31, 2008 09:34 PM
PM-Performance
Aug 8, 2003 05:49 AM
