Weird Problems. Please Help!
Old May 28, 2008 | 05:30 PM
arospeedintegra's Avatar
Default Weird Problems. Please Help!
Ok here's the break down. I have a 1991 GS that has had the ignition coil replaced, and the throttle body with the TPS sensor. Still it throws a code 7. The TPS checked out fine at .4V and 5V at WOT. The CEL will come on after driving for a little. The problem is when the gas is pressed the car bogs and stalls out. Half throttle it's fine try to rev it and it stalls. What can be the problem that causes this?
Old May 28, 2008 | 10:46 PM
sjbmx's Avatar
Default Re: Weird Problems. Please Help! (arospeedintegra)
im not gonna lie, ive got no idea but i no when there is a strange problem the answer is sometimes staring you in the face
Old May 30, 2008 | 01:20 AM
bigkvn77's Avatar
check the rest of your ignition components. plugs wires etc. ive got my money on "oil in the spark plug wells". if so you need some tube seals.
redraven_k6
Apr 19, 2010 09:07 PM
crnimacak
Jan 19, 2006 04:59 PM
1BadDC2
Jan 17, 2004 06:36 PM
