milling of head question
Old Jun 20, 2002 | 02:58 PM
Urban Business
Guest
Posts: n/a
Default milling of head question
does milling a head change valve adjustment specs?
bleh, i get my head milled, can i adjust valves to stock specs and be all right or will i have to adjust them to something other than stock specs?
Old Jun 21, 2002 | 10:13 AM
jetdriven's Avatar
Default Re: milling of head question (TorteX)
milling a head will not change your valve adjustment specs. it WILL however change the cam-to-crank clearance and make you get adjustable cam gears.
Old Jun 21, 2002 | 10:56 AM
Urban Business
Guest
Posts: n/a
Default Re: milling of head question (jetdriven)
awesome, how do you measure the cam to crank clearances?
Old Jun 21, 2002 | 11:09 AM
Sleeper's Avatar
It will decrease the distance between the crank and cams. The timing belt remains the same length, retarding the cams 1deg for every .012" off the head or block. So for every .012" removed, you advance the cams 1deg to get back to true "0". What you need to worry about is piston to valve clearance, which involves either check springs or clay.
Check here for how to:
http://www.c-speedracing.com/howto/claymotor/clay.html
[Modified by Sleeper, 8:19 PM 6/21/2002]
Old Jun 21, 2002 | 12:08 PM
Urban Business
Guest
Posts: n/a
Default Re: milling of head question (Sleeper)
so were retarding cool
now we're advancing?
cam timing is retarded by 1* per .012 correct? the advancement was a typo?
[Modified by TorteX, 3:09 PM 6/21/2002]
Old Jun 21, 2002 | 12:20 PM
Sleeper's Avatar
No, the advance is to correct the retard. So if .012" = -1deg, then adding a degree back would put us at true zero, instead of -1deg.
Old Jun 21, 2002 | 01:36 PM
Urban Business
Guest
Posts: n/a
ahh ok cool. so i will be advancing my cam over its stock setting once head is milled
Old Jun 23, 2002 | 10:12 AM
jetdriven's Avatar
Jakester9500
Jun 20, 2017 12:57 AM
JDM_EK4_Coupe
May 15, 2007 06:21 PM
HamiltonRex
Mar 2, 2006 06:28 PM
DJ Gurgla GSR
Dec 7, 2005 05:12 PM
rmcdaniels
Oct 26, 2005 12:57 PM
