milled head timing problems
Old Feb 14, 2003 | 02:03 PM
slowassgsxr750's Avatar
Default milled head timing problems
i have a gsr with a head milled 30 thousand,timing is off by half a tooth,how would i fix timing,i have cam sprockets,how many degrees should i advance on each sprocket,is there any other way to fix timing?
Old Mar 5, 2003 | 10:41 AM
Watkinsm3's Avatar
Default Re: milled head timing problems (singleslamrex)
Did you ever get a answer to this question?
Old Mar 5, 2003 | 11:31 AM
Sleeper's Avatar
Advance 1deg(both cams) for every .012" of material removed. You want +2.5IN, +2.5EX for .030".
Old Mar 5, 2003 | 12:18 PM
Watkinsm3's Avatar
Default Re: milled head timing problems (Sleeper)
I'd imagine there is no way around this without having adjustable cam gears installed? These gears are, unfortunatly, illeagle for the class of racing I compete in.
Old Mar 5, 2003 | 12:54 PM
Sleeper's Avatar
Default Re: milled head timing problems (Watkinsm3)
Have you ever thought of having a second keyway cut into your stock gears, 180deg of the stock keyway? You would have to figure how much advance you want, and place the keyway accordingly. Technically, they would still be stock gears.
Old Mar 10, 2003 | 01:26 AM
yeah i did have it fixed,i got it on dyno,thanks though
Old Mar 10, 2003 | 09:32 AM
joshwhe's Avatar
they make offset keys too
neofreak
25
Jan 1, 2007 12:33 PM
Bevin
Sep 19, 2006 11:01 PM
blowme
Nov 11, 2005 11:40 PM
incognitoracerr
Apr 22, 2003 12:47 PM
Rhetoric
Sep 11, 2002 10:02 PM
