might be a stupid question
Old Nov 29, 2006 | 04:06 PM
cydeephek's Avatar
Default might be a stupid question
my rpm is idling low 4-5 when it should be at a grand. how do i tighten the throttle cable? any help would be appreciated.
Old Nov 29, 2006 | 06:52 PM
02 accord's Avatar
Default Re: might be a stupid question (cydeephek)
It IS a stupid question if you don't say what year/car and what engine.
Old Nov 29, 2006 | 07:54 PM
JimBlake's Avatar
You DON'T use the throttle cable to set idle RPM. Regardless of what year or model, the throttle cable should go a little slack so it never holds the throttle open.
Old Nov 29, 2006 | 08:32 PM
eda6's Avatar
disconnect the iacv. you'll get a code 14. locate the idle adjust screw on the side of the tb and raise your idle speed.
turn car off and reset the ecu.
Old Nov 30, 2006 | 04:59 AM
JimBlake's Avatar
Default Re: might be a stupid question (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the iacv. you'll get a code 14. locate the idle adjust screw on the side of the tb and raise your idle speed.
turn car off and reset the ecu.</TD></TR></TABLE>Yes. Depending on what year/model/engine you're talking about, you use that method to set the idle speed to some specific RPM that's LOWER than the normal operating idle. (That's called the 'base' idle speed, maybe somewhere from 400 to 600 rpm.) When you plug the IACV back in, the RPM goes up where it belongs.
asocallocal
Sep 23, 2010 06:20 PM
oohondazoo
Jun 9, 2007 08:08 AM
emooheo
Mar 23, 2007 02:34 PM
korndog
Sep 14, 2004 05:59 AM
wantmorepower
Aug 21, 2001 12:08 PM
