compression ratio??
Old Nov 29, 2006 | 01:38 PM
rrmorseb18c's Avatar
Default compression ratio??
when a piston is rated for say 9:1 cr for a b18c, is that with the block not being decked at all and with stock size rods and crank?? Ive went to websites that will say the piston to deck height but is that height only different then stock because the piston is different??
Old Nov 29, 2006 | 02:08 PM
memorybox's Avatar
Default Re: compression ratio?? (rrmorseb18c)
yes if a piston is rated for 9:1 compression that is assuming you are using the stock rods/crank and that the block has not been decked
look up a compression calculator and you can figure up your compression with different rods
here is an example of a calculator:
http://www.knology.net/~jediklc/D.htm
Old Nov 30, 2006 | 05:16 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: compression ratio?? (memorybox)
try this one for a b series
http://zealautowerks.com/
TravisBiggie
Feb 23, 2015 01:11 PM
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
dc2_poojan
Jul 5, 2011 12:30 PM
crxvtecturbo
Jan 12, 2005 03:40 PM
Attoir
Aug 1, 2002 08:09 AM
