Messed up screw!
Old Aug 26, 2005 | 12:36 PM
  #26
R-Toyz.com's Avatar
I've had no luck with bolt extractors...i've broke a couple of them already....best bet would be to drill the head off as most of the guys above suggested.
Old Aug 26, 2005 | 02:52 PM
  #27
...rohit's Avatar
Default Re: (rtzcom)
i just wanted to say thank you to everyone! i took the hub off and had to take it to a metal shop as the screw was extremely hard material and wouldnt budge at all. thanks all!
Old Aug 26, 2005 | 03:31 PM
  #28
BigMoose's Avatar
Default Re: (desipiE)
For future reference, let me share some tips. I ended up consuming 5 to 8 mounted grinding stones for sharpening a chainsaw in a high speed air die grinder to get a similar hardened fastner to break. Those grinding stones are like 5/32 diameter with about an inch of abrasive and an 1/8 inch shank.
I would have bet if you used RJ's technique to load the rotor and put some good stress in that stuck screw, that with a little grinding you could have gotten the head to pop off.
If it was me, I would have loaded the drum like RJ said, gotten the rotor to lift a little off the hub cockeyed, then I would have hit the rotor opposite the stuck screw (where you got the other screw out) and I bet I could have popped the stuck screw.
my1992cb7accord
Dec 18, 2011 05:00 AM
toguemaster
Suspension & Brakes
May 27, 2006 01:25 PM
CivHatchH22
Mar 7, 2004 09:05 AM
Flux
Apr 1, 2003 07:44 PM
Kamin
19
Jun 24, 2002 12:05 PM
