Mechanical Differences?
Old Jan 25, 2002 | 06:47 AM
GSR_Hacker's Avatar
New User
Default Mechanical Differences?
I have a 2001 GSR, and have heard different rumors from many different sources... I am looking for a REAL and TRUTHFUL answer from someone that knows for sure...
Are there any mechanical differences between the 94-99 GSR and the 00-01 GSR? Other than ECU, and external differences... I am basically pinpointing to changes that affect engine performance. Are there any differences? I know the engine codes are the same... B18c1, but is there anything different going on?
Thanks.
Old Jan 25, 2002 | 07:27 AM
Spade's Avatar
Default Re: Mechanical Differences? (GSR_Hacker)
Just to keep this in the run. TTT
I don't know.
Old Jan 25, 2002 | 11:08 AM
Kamin's Avatar
Default Re: Mechanical Differences? (Spade)
ok 94-96 are obd1 96+ are obd2.
all the corosponding parts are diffrent (distributor, etc)
as for a list i dont know. someone should answer.
Old Jan 25, 2002 | 01:26 PM
Kataku2K3's Avatar
Default Re: Mechanical Differences? (KAMiN)
94-95= OBD 1, 96-98= OBD 2, 99+OBDb Let's just start off with the 94-95 GSR, differences from OBD1 to OBD2=secondary O2 sensor, different pin locations on the distributor and alternator, and a crankshaft speed fluctuation sensor. I believe that the 99+ motors are still the same (no new sensors on the motor). 96-98 ECU's use A,B,D 99+ use A,B,C.
[Modified by JDMspecEG6, 10:27 PM 1/25/2002]
Old Jan 25, 2002 | 02:11 PM
reefer_bob's Avatar
2000 and 2001 have a shorter Cat. Converter.
Reefer_Bob.
Old Jan 28, 2002 | 03:53 PM
GSR_Hacker's Avatar
New User
Hmm... That it? I just wondered cause it seemed as if a stock OBD I is much more powerful than a stock OBDII+ etc... just wondering... thanks....
Old Jan 28, 2002 | 06:07 PM
Jared's Avatar
I'm of the believe that the OBD1 GSRs are a little stronger as well. May have to do with the tigher emissions regulations applied to OBD2 vehicles.
civicb16eg
Jan 7, 2007 08:58 AM
IVI
Jul 10, 2006 02:37 PM
Mr. Em1
Jun 4, 2006 07:23 AM
CHONCH
Jul 20, 2002 07:05 PM
SixPAK
Dec 17, 2001 03:02 PM
