difference between obd2 and obd1 distributor
Old Jul 9, 2006 | 09:28 AM
IVI's Avatar
IVI
Default difference between obd2 and obd1 distributor
What is the difference between an obd2 or obd1 distrubutor? How do you find out which one you need?
Also is there a difference between the different b-series motors available?
Old Jul 9, 2006 | 09:36 AM
SuzukaBlueAP2's Avatar
Default Re: difference between obd2 and obd1 distributor (IVI)
I'm pretty sure the electrical connectors are different.
Here's an excerpt from discussion on this over at T-I.net
GSR/ITR cannot have LS and LS cannot have GSR/ITR.
if the car is OBD 1 (94-95) It cannot have a OBD2 (96-01) distributor for that same engine model.
I am not sure if an OBD2a (96-99) GSR is different than an OBD2b (00-01) GSR with the revision of the OBD 2 system. Someone else has to clarify that.
B18B1 for OBD 1 interchangable: 94 LS can swap with 95 LS
B18B1 for OBD 2 interchangable: any year 96 to 99 LS can swap with reach other within those years.
B18C1 for OBD 1 interchangable:94 GSR can swap with 95 GSR
Check on OBD2 GSR swapability.: Not sure if OBD2a can swap with OBD2b for GSR only.
B18C5 OBD 2 interchangable: 97-01 ITR can swap with each other within those years.
Old Jul 9, 2006 | 09:55 AM
IVI's Avatar
IVI
Default Re: difference between obd2 and obd1 distributor (SuzukaBlueAP2)
so just the electrical connectors are different?
so fitting would work just would need to re-wire the plugs?
Old Jul 10, 2006 | 05:36 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">so just the electrical connectors are different?
so fitting would work just would need to re-wire the plugs?</TD></TR></TABLE>
i think you can re-wire it to work. I cant remember if its OBD0 that can be rewired though.
Old Jul 10, 2006 | 02:37 PM
mmuller's Avatar
Mad Scientist
Default Re: difference between obd2 and obd1 distributor (JDM knowledge)
obd1-2 are the same; just wiring.
obd 0 is not compatible with the rest.
pulse reading is different, obd1 reads more pulses per revolution
Mikeliebman
Nov 5, 2014 12:25 PM
AhNtsum
Jan 11, 2008 03:44 PM
egg_baLLa
Mar 5, 2005 04:17 PM
MrEg
Aug 28, 2003 09:26 AM
