Main Relay testing procedure
Old Mar 29, 2005 | 06:22 PM
BigDaddyRich's Avatar
Default Main Relay testing procedure
There are several versions on instructions posted and several different pinned relays.
Can someone tell me the correct testing for this particular relay?
I am using the schematic diagram and holding my relay to match. I am not using the etched ACTUAL locations pictured in the 3-D pic. Am i correct in the following...
When I test schematic pin#1(+) to schematic Pin#3(-) I get power.
I also get power when I test from schematic pin#1(+) to schematic Pin#6(-)
Does that mean it is a dead relay?
I have attempted to test using these posted docs...
There are variations I have seen posted that go a different route. I have read some docs that reference #4 and #8 but apparently this relay that I have (pictured above RZ 0132) does not have a pin#4?
Any help would be appreciated.
Old Mar 30, 2005 | 05:00 AM
Up for any ideas..... Im heading to the dealer at lunchtime.
Old Mar 30, 2005 | 05:49 AM
JimBlake's Avatar
Default Re: (BigDaddyRich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDaddyRich &raquo;</TD></TR><TR><TD CLASS="quote">When I test schematic pin#1(+) to schematic Pin#3(-) I get power.
</TD></TR></TABLE>You mean power or continuity? And are you energizing the relay when you check this? If you get continuity between 1 & 3 when the relay isn't energized, it's bad.
I think you can do the checks using that procedure, but substitute terminal 6 where it says 4.
Old Mar 30, 2005 | 05:56 AM
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">You mean power or continuity? And are you energizing the relay when you check this? If you get continuity between 1 & 3 when the relay isn't energized, it's bad.
I think you can do the checks using that procedure, but substitute terminal 6 where it says 4.</TD></TR></TABLE>
Edited:
Jim..... using the actualy markings on the relay...
1 & 3 = No continuity ---&gt; next step
(+)4 & (-)8 --relay powers up tested 5 & 7 - continuity good ----&gt; next step
(+)5 & (-)2 --relay powers up tested 1 & 3 - continuity good ----&gt; next step
(+)3 & (-)8 --relay powers up tested 5 & 7 - continuity good.
end of test.
I will assume my relay is good.
Modified by BigDaddyRich at 10:27 AM 3/30/2005
Old Mar 30, 2005 | 10:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDaddyRich &raquo;</TD></TR><TR><TD CLASS="quote">I will assume my relay is good.</TD></TR></TABLE> Looks like it.
Wildwilly3
Mar 5, 2019 04:41 PM
SIMJ
Mar 3, 2012 09:14 PM
wood
Oct 8, 2009 02:36 PM
4gen5thtime
Apr 22, 2009 03:46 PM
C8V6C
Jan 20, 2005 09:46 PM
