main bearing question quick!!!!!!!
Old Feb 25, 2006 | 10:35 AM
hatchbackjdm's Avatar
Default main bearing question quick!!!!!!!
my honda service manual says that the main and ros bearins are select fit, meaning that there should be a color code for each individual bearing to fit into each journal. i got a set of standard federal mogul bearings and there is no indication of any of the bearings being different from each other. will these bearings work or do i need to get the ones from honda?
Old Feb 25, 2006 | 12:01 PM
nsxxtreme's Avatar
Default Re: main bearing question quick!!!!!!! (hatchbackjdm)
I ended up buying the honda bearings. The size is also stamped on the crank.
Old Feb 25, 2006 | 12:53 PM
civic_gsr_transplant's Avatar
i would also buy the honda ones because they are supposed to be different
Old Feb 25, 2006 | 04:16 PM
86si's Avatar
honda bearing clearences are alot tighter than the standard bearings. they will work. just measure the clearences.
1988dxsedan
Engine Machining & Assembly
105
Jan 8, 2017 12:06 PM
1988dxsedan
12
Nov 22, 2015 06:28 PM
SiRkid
Jun 13, 2009 01:51 PM
b20vcrxsir
Feb 17, 2009 06:39 AM
TurboKneeGrow
Mar 18, 2008 07:22 PM
