Mahle Pistons w/Eagle Rods?!
Old Dec 26, 2005 | 02:12 PM
fastrcars's Avatar
Default Mahle Pistons w/Eagle Rods?!
I heard there were no need to replace sleeves when going for the Mahle pistons?
How much HP could i gain to step up to 11.3-1 c/r compared to 10.6 which is standard on my H22 JDM engine?
Of course i will change the whole head as well for some better Camshafts and other springs/valves so i´ll be able to rev uppon 9k rpm
I want to continue tune "all motor" style and no turbo what so ever..
But first i want to see if its worth it or not ...really love N/A so..
(Im tuning with S300)
/ Jonas
Old Dec 26, 2005 | 02:22 PM
1SlowB16EF's Avatar
kinda vague cant really answer that
Old Dec 26, 2005 | 02:31 PM
fastrcars's Avatar
Default Re: (1SlowB16EF)
Ok ok..
what cant u answer..if the Mahle doesnt need resleeve...or the HP ?
Old Dec 26, 2005 | 02:41 PM
siblues's Avatar
Default Re: (fastrcars)
https://honda-tech.com/zerothread?id=1406865
These guys should be able to answer your questions
Old Dec 26, 2005 | 03:36 PM
Shawn C's Avatar
In The Garage
had several issues with mahle pistons not having deep enough valve reliefs.
they design pistons for stock cam profiles it seems. try using a big vtec lobe and they hit. seen several engines turn into junk.
no bueno in my book. i've built 5 or 6 engines with the mahle's and i don't plan on doing it again.
there's no smoothing on them at all, very sharp, steep domes, etc.
if you have a jdm h22, and will stay all motor, with no nitrous, etc.. then just mill the head, use some flat-face valves, and go with a big cam. really high compression doesn't make near as much power on honda engines as people think. bigger bore and big cams is where i see the best results. don't stroke it, and rev the **** out of it. oh yeah!
try to keep your combustion chamber looking like a rounded triangle /_\ much better for concentrating the combustion explosion straight downward on the center of the piston, instead against the sides of a big dome.... think about it before you just go buying parts
kingofbattle909
Mar 2, 2012 06:14 PM
civic-r11
Jan 28, 2009 06:33 PM
civic_saints1
Jul 16, 2007 07:59 PM
Johnny_Rocket
Jun 11, 2005 12:13 PM
