lsvtec help
Old Feb 14, 2004 | 12:18 PM
jooky's Avatar
Default lsvtec help
ok im new to hondas but i got a few ?'s. i have a 91 hatch that had a 92 Ls in it. That motor threw a rod so i am looking at a lsvetc. My question is ......can i put in this motor using the ecu that already there and buy some sort of controller to run the vtec or do i need a new ecu. thanks guys
Old Feb 14, 2004 | 01:20 PM
SkRiBLaH's Avatar
Default Re: lsvtec help (jooky)
you need new ecu. chipped p28 is best + vafc
Old Feb 16, 2004 | 10:49 AM
jooky's Avatar
Default Re: lsvtec help (SkRiB)
what is the p28 and vafc
Old Feb 16, 2004 | 10:56 AM
fearless_dsm's Avatar
p28 is an ecu from a 92-95 civic ex/si and its obd1 vtec...to use that youd have to get a conversion harness since your car is non obd...vafc is a vtec controller...you can just use you ecu and get it chipped and use a switch...or just use a switch on the stock ecu...or just get a pwo or pr3 ecu...
Old Feb 16, 2004 | 10:58 AM
Default Re: lsvtec help (fearless_dsm)
pr3 or pwo are from japanese 90-93 integra's and 89-91 crx/civics
Old Feb 16, 2004 | 11:11 AM
jooky's Avatar
what do you mean by a switch. like i activate the vtec by pressing a button. i deffinatly dont want that. and what would be the best possible setup
Old Feb 16, 2004 | 11:13 AM
mmuller's Avatar
Mad Scientist
best and cheapest way to go is run a pr3 ecu or a chipped p28 with a conversion harness as sayd above.
I advice against running any kind of rpm activated switch and your ls ecu, since timing and fuel will be way off
Old Feb 16, 2004 | 11:30 AM
jooky's Avatar
so with a pr3 ecu i will still need the conversion harness? and it will be ready to run the vtec like stock without any buttons and ****
Old Feb 16, 2004 | 05:30 PM
jooky's Avatar
any help
Old Feb 16, 2004 | 05:46 PM
jooky's Avatar
sounds like the p28 is my best bet cuz it will already have the vtec function
Old Feb 17, 2004 | 08:43 PM
swaytec's Avatar
Default Re: (jooky)
p28 will work but ur car is obd0 so youll need to convert to obd1 vafc will help tweek and tune ur curves and vtec engagement u could have an obd1 ls in there which would save u time and money on the wiring or conversion harness check ur block and ecu to see what u have before you start buying
Old Feb 17, 2004 | 09:05 PM
jdmexsi's Avatar
Default Re: (jooky)
your better off using a pr3 and just adding the vtec wires to your harness you already have. its your cheapest bet and it already plugs into your harness so no converter harness is required and you will find just as many chips for a pr3 as a p28 and unless your gonna be hardcore about tuning you wont need a vafc with a chip
Freckles
20
May 3, 2012 06:17 AM
Jdm_Ego
12
Sep 27, 2010 03:42 AM
egboostin6
Mar 20, 2007 12:28 PM
Youlose1305
Jul 10, 2006 09:16 AM
trustnoone7935
Nov 24, 2004 08:34 PM
