ECU for ls/vtec????
Old Jul 8, 2006 | 05:41 PM
Youlose1305's Avatar
Default ECU for ls/vtec????
i have a 91 crx hf and was wondering which ecu is the best choice??? i heard pr3 and p28 but have not gotten a for sure answer........thanks
Old Jul 8, 2006 | 06:36 PM
Default Re: ECU for ls/vtec???? (Youlose1305)
any1?
Old Jul 8, 2006 | 08:48 PM
boostedblkef's Avatar
im using a p06 converted to vtec
Old Jul 8, 2006 | 09:23 PM
eg6T's Avatar
Default Re: ECU for ls/vtec???? (pittbullracer)
im using a p28..
Old Jul 9, 2006 | 01:40 AM
Default Re: ECU for ls/vtec???? (eg6T)
so a stock ecu will do just fine??
Old Jul 9, 2006 | 02:21 AM
eg6T's Avatar
im sure it would do ok,you probably wont get all the potential out of it though.chip it with crome/uberdata and get it tuned would probably be best
Old Jul 9, 2006 | 09:28 AM
how much does the chip and tuning cost???
Old Jul 9, 2006 | 10:04 AM
7rrivera7's Avatar
If you are ODB0, a PR3 or PW0 are your only VTEC chioces. If you are ODB1, then a P28 is fine but you should use a 1.8 liter basemap. A stock P28 program will probably run lean...
Old Jul 9, 2006 | 08:33 PM
lobudgetr's Avatar
Default Re: ECU for ls/vtec???? (7rrivera7)
I'm running P28 with custom program in my CRX, but my car is wired for OBD1, That would be another determinging factor are you OBD0, or OBD1?
Old Jul 9, 2006 | 10:26 PM
Default Re: ECU for ls/vtec???? (lobudgetr)
i am obdo but i am gonna get the harness conversion from hasport so i can use obd1.......
Old Jul 10, 2006 | 07:32 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
PMed
Old Jul 10, 2006 | 09:16 AM
mtber's Avatar
http://phearable.net/tech/efibeginnerguide.html
TurbodTegra
Mar 10, 2011 12:46 PM
SingleCamin
14
Mar 7, 2009 10:14 AM
egboostin6
Mar 20, 2007 12:28 PM
turbohf
Jul 17, 2005 08:47 PM
roc109
Nov 19, 2002 09:06 PM
