LSVtec disapearing CEL?
Old Apr 25, 2013 | 06:46 PM
Slacker93eg's Avatar
10 Year Member
Default LSVtec disapearing CEL?
I've been having a few issues with my fresh built ls vtec. b18b block gsr head obd1.
Check engine light comes on once I hit around 7000rpm, vtec engaged at 5000. CEL stays on, until I turn the car off. Once the car is shut off or restarted the CEL is gone. I've tried to plug the jumper while the engine was running but it didn't do anything.
The engine also dies out once warm, the idle will bounce between what looks like 300-1000rpm and finally die out. No CEL when this happens though
I'm not sure where to even begin here
Old Apr 26, 2013 | 05:26 AM
10 Year Member
Default Re: LSVtec disapearing CEL?
ttt
Old Apr 26, 2013 | 05:56 AM
grumblemarc's Avatar
The Grumpiest
What do you mean it didn't do anything? Light stay on? Never come on? What ECU? Stock? Chipped? In what car?
You've not given up enough information.
Old Apr 26, 2013 | 06:00 AM
10 Year Member
p72 ECU chipped for 5k rpm vtec, no o2 sensor, and 8k limiter.
It's a 93 civic hatch, the CEL would just stay on steady if I tried to jump the harness, disappeared once I turned off the key
Old Apr 26, 2013 | 06:02 AM
The Grumpiest
Who chipped it? And you know those tachs bounce around a lot and are not accurate. Wonder if you're blipping your rev limit and not aware.
Old Apr 26, 2013 | 10:54 AM
jdmh22eg2's Avatar
why in the hell would u delete the O2 in your tune? that prob has ALOT to do with your fucked up idle and wanting/dying out. my guess is that your prob is with the 02 and some sort of ign/fuel cut due to O2
project91crxsi
Feb 20, 2012 07:24 AM
sumoneEK
Nov 22, 2010 11:29 AM
skUnK2jdm
26
Feb 7, 2008 10:08 AM
BigIslandBoi
Oct 12, 2003 10:17 PM
