lsvtec compression test results inside, need to worry?
drop a cap of oil in the cylinder your testing and see if that brings it up.
if so then it could be your rings.....
does it smoke? when u rip on it?
This. I've done this before and it has made all the difference in response/power. Without a wideband it is tricky to fully understand what the motor is doing as the spark plugs offer a pretty narrow glimpse into how things are running, even if you know all the places to check them.
most of the plug looks ok but the ground strap is a little on the white side. should have a touch more brown/tan colour than just slightly off white
Hondizzle!
Sep 13, 2005 09:13 AM
