Lsv crank wont spin
Old Dec 8, 2011 | 09:41 PM
nestea8869's Avatar
Default Lsv crank wont spin
I just built my lsv all brand new block bored half over and head
from machine shop
81.5 type r pistons gsr head stock cams
I spun the crank before it was put together at ease now
That it has the head torqued down pistons in valve job done
Tranny mounted the crank doesnt want to spin all the way
Itll spin a little bit with force then wont move at all can
Someone help me or give me ideas why it wont move?
Old Dec 8, 2011 | 09:49 PM
cibao2ner's Avatar
Default Re: Lsv crank wont spin
is your clutch slave cylinder on the tranny? once engine is together crank will be hard to spin because your fighting against the spring pressure from the valvetran...also only spin counter clockwise towards the front of the car..
Old Dec 9, 2011 | 05:53 AM
nestea8869's Avatar
No the slave cylinder is not conected ill try connecting it and see
Old Dec 9, 2011 | 11:17 AM
fcm's Avatar
fcm
Old Fart
Not sure what diff. the slave cylinder would make, but I do agree that turning crank after engine is assembled will be a "lot" harder, however turning and then stopping sounds like you may have the valve timing out, [valves contacting pistons].
First thing I would do is confirm valve timing iscorrect, if for no other reason then to elliminate it as the problem. 94
Old Dec 9, 2011 | 11:31 AM
nestea8869's Avatar
Yea the guy who did my bottom end work said the same thing
With the valves hitting what should I put em at right now their at 6
Old Dec 9, 2011 | 11:44 AM
kyden's Avatar
what is at 6? the cam gears? yikes. put stock gears back in if so.
Old Dec 9, 2011 | 12:29 PM
DirtyDA9's Avatar
Valve timing not set right.
Old Dec 9, 2011 | 04:10 PM
nestea8869's Avatar
Thevalves r set at 6
Old Dec 11, 2011 | 07:46 PM
10psiLsEf2's Avatar
Sounds like a rod issue.
The rod bearing caps will go in 2 ways but only 1 way is correct. if they were installed wrong the crank will be hard to turn.!!!!!!!
Speeaking from experience.
My b18b1 rods have a number 1 on the rods. half of the 1 is on the rod and the other half is on one side of the bearing cap!!!!! they must line up to complete the number or it wont spin freely.
best of luck
Old Dec 11, 2011 | 07:48 PM
10psiLsEf2's Avatar
also remove all sparkplugs and see how it feels. it its smooth than your fighting compression
Old Dec 12, 2011 | 05:26 AM
kyden's Avatar
what does that even mean?
Old Dec 13, 2011 | 04:47 PM
Ratt731's Avatar
Sounds like piston piston hitting valve, like already mentioned, If your valves are contacting the piston I would pull the head and make sure they are not damaged, even though youre cranking it by hand it could still damage the valve
TecBoyRSA
11
Oct 29, 2018 08:42 AM
gp356
12
Apr 23, 2013 06:23 AM
JFG Kevin
Aug 28, 2006 09:47 PM
blue153
Aug 28, 2006 05:50 PM
optoomistic
Oct 27, 2003 03:48 AM
