LSD install question
Old May 16, 2003 | 01:52 PM
Myleatherseats's Avatar
Default LSD install question
ok i need some wisdom here...i have what im told a 98 CTR LSD from Ebay...came with the VSS gear...so i have my tranny out and i get the diff. out then take the final drive gear off...and i goto put the final drive on the LSD and the gear is too small nor do the bolt holes line up..so what do i need to do in order to use the LSD..do i need to purchase a different final drive..and also will it fit in my transmission once i get the bearings on, i believe the shafts that the bearings sit on are the same size...is all i can see is that the final drive doesn't fit
help please
i have a 99civic si(b16a2)/stock motor and tranny
Old May 17, 2003 | 03:26 PM
Default Re: LSD install question (Myleatherseats)
well i take it no one knows...well this is what i have gathered and believe how to fix it...the CTR/ITR lsd won't work with the final drive gear off of a non-lsd transmission..it will only work with transmissions with lsd's or that have the option to upgrade lsd (ie. the USDM ITR, JDM CTR) so i believe you have to get the final drive off of one of those or a JDM ITR if you want to upgrade your gear ratios...but to keep the 4.400 you can use a CTR or USDM ITR final drive due to the thread pattern on the gear itself is the same is the lsd...but comment please let me know if you guys have anything to say or thoughts...thanks
sitham_pillay
Transmission & Drivetrain
Apr 21, 2014 06:37 AM
racinjason
Mar 28, 2005 06:56 AM
SupaFly_Honda
May 12, 2004 05:12 AM
b16a1sirhb
Nov 13, 2003 05:00 PM
sirminder
Sep 5, 2003 11:34 AM
