ls/vtec swap problem.. getting engine code
Old Apr 12, 2006 | 06:57 AM
tesfrank's Avatar
Default ls/vtec swap problem.. getting engine code
just finishing ls/vtec swap in my 90 integra... and I have some problems:
1- my PR3 ecu fuelcut at 7000rpm, isnt supposed to rev up to 8200rpm?
2- I'm getting codes 6,7,9 & 10 from the ecu...
3- The engine is really hard to start and has a poor throttle response when cold
4- Vtec not engaging...
When I use my old PR4 ecu it starts and runs great until the engine become warm, then "crank position sensor" engine code come on and the engine idle at 1500rpm
Any idea?
thanks for help...
Old Apr 12, 2006 | 08:16 AM
IntegraMastaz's Avatar
Bump for a good ****.
Old Apr 12, 2006 | 08:49 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: ls/vtec swap problem.. getting engine code (tesfrank)
https://honda-tech.com/zerothread?id=682412
see the link above for the cel codes.
did you keep the car obd0 or converted to obd1?
Old Apr 12, 2006 | 09:11 AM
tesfrank's Avatar
I was planning to make the convertion but finally decided to keep it obd0... Is it possible that I inverted some wires?
Old Apr 13, 2006 | 07:23 AM
tesfrank's Avatar
up! before I become CRAZY!!
morglum
Honda CR-V & Element
Mar 25, 2015 01:57 PM
uptownx24x
Jul 9, 2011 04:59 PM
newmarketcb7
Apr 13, 2010 10:40 AM
AllMotr
Jul 2, 2005 07:14 PM
McD
11
May 8, 2002 05:13 PM
