LS vtec leak down results
Old Sep 14, 2011 | 12:18 AM
Lsvsmoker's Avatar
Default LS vtec leak down results
I have a rebuilt ls v that smokes. 130 miles since rebuild and still smoking. I did a leakage test and these are my results:
Cylinder 1: 10%
cylinder 2: 17%
cylinder 3: 12%
cylinder 4: 9%
Keep in mind the motor is rebuilt new rings etc.... Are these good numbers since it's still not fully broken into?.
Old Sep 14, 2011 | 08:27 AM
95 integra's Avatar
Default Re: LS vtec leak down results
That's a large variance and 17% isnt good. What all was done when it was "rebuilt"? Cylinders honed?
Old Sep 14, 2011 | 08:55 AM
Lsvsmoker's Avatar
Machine shop rebuilt the motor, honed the cylinders, installed néw rings and bearings, pressure tested head, and valve seals were replaced.
Old Sep 14, 2011 | 08:58 AM
Lsvsmoker's Avatar
Was it too sooN to do a leak down test or should I run the motor the full 500 miles and allow to fully break in and try the test again??
Old Sep 14, 2011 | 11:01 AM
hybrid_KJ's Avatar
I've leakdown tested motors that hadn't even run yet and been under 7% on all cylinders. Definitely something up.
Old Sep 14, 2011 | 11:31 AM
95 integra's Avatar
Are you positive the leak down was done correctly? If so, it's time to take it back to the shop...
Old Sep 14, 2011 | 02:02 PM
Lsvsmoker's Avatar
Yeah I'm positive I did it right, I actually did the test twice. I did it wit the valve cover off and I heard air leaking through the crank case. So it seems the rings maybe be the culprit?? Can I jus rehone and install new rings??
Old Sep 14, 2011 | 09:20 PM
92EGLSVTECEATER's Avatar
The readings of 12 and 17 are not good on any engine.And if you have the cylinders were they should max should be in my book(which isn"t worth ****) 10.Can you here it coming out the tailpipe?
Old Sep 15, 2011 | 08:48 AM
95 integra's Avatar
You dont necessarily need to rehone it....or buy new rings for that matter. Were the rings installed at the proper 120* intervals w/ the oil rings at 30* (or whatever proper spec is)?
Old Sep 16, 2011 | 07:50 AM
mygoldeneg's Avatar
need a new machine shop
blue_dlb
Jun 9, 2013 08:40 AM
stockb18c
Nov 2, 2008 05:30 PM
aznxpyroboi
Dec 9, 2007 10:09 PM
timisyourfriend
Jun 22, 2006 07:12 PM
Andrew 825SM
Jun 1, 2004 07:06 PM
