LS/Vtec Buildup - Does doing it please respond...
Old May 24, 2003 | 11:46 AM
7rrivera7's Avatar
Default LS/Vtec Buildup - Does doing it please respond...
I'm finally going Ls/Vtec on my CRX and want to stay all-motor. What would be the highest compression pistons I could buy for a daily driver on 93 pump gas...11:1, 11.5:1, 12:1, 12.5:1?
What about a daily driver with a shot of nitrous on the weekends?
What about a daily driver with a JRSC at stock pressure (8 lbs)?
What about a daily driver with a JRSC and a shot of nitrous on the weekends?
Any piston brand name in particular you would recommend?
Thanks!
Old May 24, 2003 | 01:57 PM
RaIn's Avatar
12:1 is safe 12:5 is questionable
For pistons... if you want to save some money... use b16 pistons and ls rods... get the rods shotpeened and use ARP rod bolts and you will be fine... if you use a gsr head and mill it about .010 and deck the block your compression will be around 12:1
Old May 24, 2003 | 02:10 PM
dfoxengr's Avatar
Default Re: (RaIn)
13:1 is safe if you have a good tuner
all_motor_sfwd
Apr 26, 2007 09:46 PM
ApexOne
Aug 16, 2004 05:21 AM
blueskiesfade609
Nov 14, 2003 12:09 PM
chuckd05
Mar 26, 2003 08:15 AM
ls_vtec_b18a1
Oct 10, 2002 08:35 PM
