LS/vtec
Old Apr 6, 2003 | 12:58 PM
gribbs's Avatar
Default LS/vtec
How much can I expect to spend (with or without labour) to add everything I need to my LS to give it a VTEC head? I know I have the option of GSR head or b16 head but thats about all I know...
thanx alot
brad
Old Apr 6, 2003 | 02:38 PM
icelarry27's Avatar
Default Re: LS/vtec (gribbsEG8)
alot...go to c-speedracing.com and check out the parts list...and see i fyou can find prices for them. its not going to be too cheap i can tell you that right now.
Old Apr 6, 2003 | 02:41 PM
SpeedVelocity.org's Avatar
LS bottom end (crank, etc.), complete B16/B18 head from Si/GSR/ITR, VTEC wiring harness and solenoids, pistons of your choice, depending on what you wanna do (Nitrous, Turbo, NA, etc), and a good machine shop to drill your extra hole in the head for oil. As a general guide, B16A pistons are relatively low compression, while B18C5 ITR pistons are pretty high compression. It'll prolly run you around 800-1000 for all the parts, 1200-1500 total including building the motor itself.
Old Apr 6, 2003 | 03:05 PM
gribbs's Avatar
Default Re: LS/vtec (SpeedVelocity.org)
ok cool thanx that helps out a lot......i am considering sellin my EG for a DA and wondered what this would cost cause I may have enuff left over to do it
thanx alot
Old Apr 6, 2003 | 05:38 PM
lazy bum shaughn's Avatar
Actually the B16 would yield a higher compression ratio I think.
Old Apr 6, 2003 | 06:24 PM
bruthaboost's Avatar
Your best option is to just buy a 1st gen b16 long block. This way you are sure of what you are getting. Also, you'll have b16 pistons, oil squirters, and the tranny (although it's a cable one-you can get the conversion kit).
HTH
Old Apr 6, 2003 | 08:19 PM
Combustion Contraption's Avatar
Default Re: LS/vtec (bruthaboost)
b16 pistons in the b18 block will give you around 12.1:1 c/r , and with ITR youll have about a 11.1:1 so i would go with ITR for driveability, but thats just me..
Old Apr 11, 2003 | 02:53 PM
icelarry27's Avatar
Default Re: LS/vtec (lazy bum shaughn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazy bum shaughn &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;As a general guide, B16A pistons are relatively low compression, while B18C5 ITR pistons are pretty high compression.
&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
Actually the B16 would yield a higher compression ratio I think.</TD></TR></TABLE>
JDMbiAtcH
Aug 25, 2005 12:00 PM
tray3rd
11
Jun 3, 2004 12:58 PM
flyrice
Nov 1, 2003 02:19 PM
Incognito
Oct 31, 2001 11:51 AM
MXPX
Aug 29, 2001 08:22 AM
