LS/VTEC compression ratios.....
Old Oct 31, 2001 | 09:08 AM
Incognito's Avatar
Default LS/VTEC compression ratios.....
Anyone know what compression ratios of LS/VTEC motors are? I know Si and GSR heads have different CR's, so I'd assume that the CR on LS/VTECs are different with Si and GSR heads.
Basically I need to know the CR of a LS/VTEC w/GSR head, and CR of LS/VTEC on Si head, both with stock pistions. Also need to know the CR of the stock LS motor (1995 B18B1).
Old Oct 31, 2001 | 09:13 AM
rtype11's Avatar
Default Re: LS/VTEC compression ratios..... (Incognito)
depending on head dome volume a little higher, wait for someone else to do the math, you should check in at about stock 9.2:1 or 0.1-2 ponts higher.
Old Oct 31, 2001 | 09:34 AM
Incognito's Avatar
Default Re: LS/VTEC compression ratios..... (rtype11)
'99 B16A Si head with '95 B18B1 LS block, 8.5:1 compression pistons. What CR would that yield?
Old Oct 31, 2001 | 11:51 AM
newspeedR's Avatar
hmmm, sorta sounds like you dont know much about ls motor... a standard LS motor has 9.2:1 compression...
as SI head is .2 lower than a GSR head... meaning that a gsr head will yield a higher compression ratio than SI head due to the size of the port opening...
A LS/VTEC motor with stock pistons would be in the high 9's er very low 10's... most people that run ls/VTEC use b16 pistons and that yields a CR of around 11...
If you are running the 8.5 compression pistons... figure about a CR of 9.0:1... can always put a guage in the head to measure it...
just boost it till 20 psi so you can hit the 11.0...
olskoolhatchy
May 7, 2008 12:56 AM
olskoolhatchy
May 6, 2008 03:28 PM
EF8KiLLaBeE
Jan 21, 2006 10:37 AM
tunerraceteam
Jan 2, 2006 02:21 PM
MugenGSRb18
Sep 7, 2004 12:43 AM
