LS Vtec
Old Jan 31, 2009 | 09:18 AM
Streetsport's Avatar
Icon6 LS Vtec
Me and some friends have a disagreement on how to build LS Vtec motor. from what I have been hearing its a LS block and everything else is GSR. if Im wrong please correct me
Old Jan 31, 2009 | 12:14 PM
bigD's Avatar
Default Re: LS Vtec
a ls block with a vtec head from a gsr,type r or b16.
Old Jan 31, 2009 | 09:28 PM
EGhatchLSV's Avatar
Default Re: LS Vtec
my setup
b18b1 block
b16 head
type r oil and water pump
you can use a gsr b16 or type r head, b16 and type r's are pretty much the same and there the best to use..
and its also good to upgrade to a type r oil and water pump
Old Feb 2, 2009 | 02:25 PM
so lazy's Avatar
Default Re: LS Vtec
Streetsports you're correct and the other guys are correct also that just posted.
LS-VTEC:
LS bottom-end
Vtec head (B16,GSR,ITR,B17)
Oil Pump to use on the LS block.. Bseries 96+ oil pumps are all the same.. ITR GSR LS B20 who gives a crap.. I work for Honda and I've looked at all the part numbers if you're buying an ITR one you're getting robbed.. I just recently ordered a b16 one and it was a GSR part number.. $80... I called our Acura store $97 sooo we're playing the name brand game here with the oil pumps.
Timing belt to be used, will be depending on what type of water pump you're going to run.. ITR,GSR are the same. LS water pump you use a LS timing belt.. you get the picture..
JDMCIVIC919
May 4, 2012 02:52 PM
b16-bomber
Nov 8, 2006 05:56 PM
volc0m08
30
Jun 22, 2005 02:29 PM
99lsvtecauto
Nov 16, 2003 03:09 PM
