ls / s2000
Old Jun 22, 2002 | 08:56 AM
EGlovr's Avatar
Default ls / s2000
is there any way you can put an s2000 head on an ls block, or any other b series block??? just wondering.
Old Jun 22, 2002 | 09:39 AM
spikius's Avatar
Default Re: ls / s2000 (EGlovr)
I don't think there is, it's for hondas newer block designs. I've heard that it will bolt on to the new K series engine blocks though, although I don't know if the K blocks rotate opposite the S2000 (F?) blocks (the K's rotate opposite the B's)
Old Jun 22, 2002 | 09:47 AM
B18C-EJ1
Guest
Posts: n/a
not a chance in hell.....
Old Jun 22, 2002 | 10:30 AM
EGlovr's Avatar
Default Re: ls / s2000 (B18C-EJ1)
well are any parts of the s2000 interchangable with anything else?
Old Jun 22, 2002 | 10:34 AM
B18C-EJ1
Guest
Posts: n/a
Nothing B-Series. Maybe you can transfer over to a K-series engine, but otherwise......
Old Jun 22, 2002 | 04:39 PM
EGlovr's Avatar
can you swap it into anything? isnt it rw drive?
Old Jun 22, 2002 | 04:54 PM
Kamin's Avatar
no
not unless you have gobs of money.
Old Jun 22, 2002 | 06:12 PM
Mrfirefox's Avatar
Default Re: ls / s2000 (KAMiN)
no
gobs you say
you crap wait i'm poor
Old Jun 22, 2002 | 08:24 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: ls / s2000 (Mrfirefox)
integra = B series
stook = K series
B does not equal K
[Modified by dLo GSR, 10:26 PM 6/22/2002]
Old Jun 22, 2002 | 08:59 PM
Mr Miyagi's Avatar
Default Re: ls / s2000 (dLo GSR)
Keep in mind that the S2000 motor spins the opposite direction of the B-Series motor, so even if you were able to swap it into a FWD car, you're going to have hella transaxle problems. If you were, in theory, able to get the S2K motor into a FWD car, you would have to mount it on the opposite side as all the other 'normal' hondas (i.e. not an RSX or new Si)... yeah, on the passenger side, and the driver side would have the tranny like, say... a Saturn, or a Neon. But if you were to mount it on the same side as a GS-R, then you're going to have 6 reverse gears and 1 forward gear. And that head is a lot narrower than a B-Series. So save the custom fab for another day.
Old Jun 23, 2002 | 07:13 PM
EGlovr's Avatar
Default Re: ls / s2000 (Gold dubs)
thanks
Nikos
K Series
70
Oct 28, 2008 04:13 PM
evileye
Feb 26, 2008 04:41 PM
chulowithakhulo
Honda S2000
Jan 10, 2005 06:38 AM
BxGSXR3
Mar 14, 2004 01:08 AM
HX_Guy
Honda S2000
Jul 10, 2001 08:33 AM
