ls crank
Old Feb 17, 2008 | 11:41 AM
boostedb20z's Avatar
Default ls crank
ok i got a b18 and im building it and it had some good miles on it but the crank looks great no marks or anything. my ?? is do i have to get it balance or polished.
My build
b18a block
81mm honed still in spec
srp pistons 10:5:1 .074 head gasket makes it 9:5:1
eagle rods
acl baerings
crank????
b18 head non v-tec
5 angle valve job
dh-racing springs and retainer
stock cams for now
tuned on crome by me
1000cc injectors
walbro 255
e85
itr tranny 4.7 final drive
Old Feb 17, 2008 | 12:33 PM
base-op.1320's Avatar
Default Re: ls crank (boostedb20z)
I would do both for sure
Old Feb 17, 2008 | 12:37 PM
mtber's Avatar
Default Re: ls crank (base-op.1320)
I doubt it will have to be balanced. You can balance the complete rotating assembly if you want to get crazy, however I have seen tons of motors last a very long time without doing so.
Concerning the valvetrain you are running, you may want to consider selling it & buying something with a better reputation.
Concerning crome, I would look into neptune or ectune
Old Feb 17, 2008 | 12:43 PM
whats wrong with dh-racing there the only company that will stand behind there $hit for life supertech wont cuz steel and titanum dont got together ti will eat the steel spring and crome i have tuned alot of cars on it and i like it. but thanks for your help and im only going for 500whp
Old Feb 17, 2008 | 01:02 PM
Default Re: (boostedb20z)
I would balance it because I believe my unbalanced assembly is what killed my oil pump.
Old Feb 17, 2008 | 03:01 PM
blkb18's Avatar
Default Re: (base-op.1320)
not to thread jack, but what harmonic balancer where you running base-op.1320?
Old Feb 17, 2008 | 03:22 PM
Default Re: (blkb18)
Its not a harmonic balancer its a harmonic damper because these are internaly balanced, it was a fluidampr thats why I'm leaning torward the crank not being rebalanced
Old Feb 17, 2008 | 03:37 PM
ya but they come from the factory balanced and i would think the only time it would need to be rebalanced is if you have to get the crank turned
Old Feb 17, 2008 | 04:31 PM
I would rebalance the assembly especially if you plan on running above normal redline, I have talked to alot of shops about my oil pump failure and they all say they balance there assemblies and told me to balance mine.
Old Feb 17, 2008 | 05:14 PM
im only reving to maybe 8500rpm
jrscb16eg6
Aug 12, 2008 03:02 PM
jmac
Mar 26, 2008 11:04 AM
boostedb20z
Feb 17, 2008 07:38 PM
sirekhatch
Feb 27, 2007 08:17 PM
scooter
Mar 4, 2003 11:05 PM
