ls b18b1 problem revving
Old Apr 14, 2011 | 05:54 PM
nestea8869's Avatar
Default ls b18b1 problem revving
so i have a 93 civic with a b18b1 and so my check engine light was on so i read the codes and it said it was the thermostat so i changed the thermostat and now when i drive it the car has a rev limit or something and stops at 3000 rpms in all the gears
can you tell me what i did wrong or what i need to fix thanks
Old Apr 15, 2011 | 04:10 AM
kyden's Avatar
Default Re: ls b18b1 problem revving
what was the actual code? there technically isn't a thermostat code.
Old Apr 15, 2011 | 05:26 AM
wc4ohio's Avatar
Yeah I've heard of this happening... apparently the computer has spotted condition that puts it into limp mode... it's not your thermostat... you'll need to fix the problem before your computer will come out of limp mode... check your distributor cap and rotor
Old Apr 15, 2011 | 09:19 AM
nikon7o7's Avatar
I just had that same issue after I fixedy erratic idle I had a rev limit of 2.5k couldn't go any higher in any gear turns out my throttle sensor was unplugged lol! Check ur electric connections, Check spark plugs, fuel filter and distributor cap, i hope that helps you somehow Brotha good luck
Edit* forgot to mention my engine is a b18a1 but how different could they be.
Old Apr 15, 2011 | 03:59 PM
nestea8869's Avatar
ok well i just noticed this morning that it works fine when cold but after heating up it wont go past i got new spark plugs wires
and the codes i think based of the guy it blinked 6 times then 17 times after
a wire hooked up to the plug that goes to the thermostat was broke so i fixed it now the water in my rasidiator resivior or however u spell it is like steaming now
Old Apr 15, 2011 | 04:20 PM
wc4ohio's Avatar
Well, the thermostat is mechanical, so whatever you hooked up won't affect its operation. If it is stuck closed, you can test it... take it out of the engine and hang it from a wire, and submerge it in a pot of water (not touching the edges of the pot). Also submerge a thermometer tip into the water (not touching the edges of the pot). Heat the pot over a burner and wait for the thermostat to open, and note the temperature on the thermometer. Check it against the temperature stamped on the back of the thermostat. If it doesn't open, or if the opening temperature is much different than the stamped temp, replace it.
It could be also that you have the wrong thermostat for your engine vs. the area where you live, so that would be a good time to check that.
I doubt this is the only problem (if it is a problem), though. I have a feeling some kind of sensor is malfunctioning.
Recklesszz
Jan 30, 2013 08:30 PM
harvinder
Dec 2, 2008 01:45 PM
JDMkidGSR
Aug 1, 2006 02:20 PM
GuyInASpeedo
14
Sep 24, 2003 07:34 AM
si95
Sep 5, 2002 11:42 AM
