lowering a 96 hatch
Old Jul 20, 2002 | 05:23 PM
LiLn81224's Avatar
Default lowering a 96 hatch
just a quick question about lowering a 96 hatch dx...if i buy ground control coilovers, would they work fine with stock shocks, or would i need any other things to lower the car properly? thanks
Old Jul 20, 2002 | 06:18 PM
GTM's Avatar
GTM
Default Re: lowering a 96 hatch (LiLn81224)
It is always necessary and most techs say critical to change your struts to aftermarket high-performance units whenever you lower your car with lowering springs or sleeve-type coilovers. You are in effect increasing your spring rate and you need a shock/strut capable of handling that increased spring rate.
Factory or stock struts usually don't last more than 2-3 weeks on average before you see fluid leaking out of the piston. Try Tokico, Koni, or KYB. We've always had success with these setups.
Good luck.
trucker01
Suspension & Brakes
Sep 12, 2014 06:02 PM
type-ONE
Suspension & Brakes
31
Aug 28, 2009 11:01 AM
kpjo4
Aug 7, 2008 04:30 AM
2dxtreme96
Suspension & Brakes
May 9, 2006 10:53 AM
LiLn81224
10
Jun 27, 2002 01:33 PM
