Lightweight pull crank HELP ME :(
Old Jan 6, 2007 | 05:49 AM
Enta's Avatar
Default Lightweight pull crank HELP ME :(
Hello. I have a honda CRX EE8 with B16A1 engine. I buy my car and I got a light weight pull crank from past owner my honda. I don't know if I install this part? I install in engine a flywheel Fidanza ( lightweight ). I scare, if I install this pull crank, my engine has destroyed. Help me please.
Old Jan 6, 2007 | 07:20 AM
non-VTEC's Avatar
Default Re: Lightweight pull crank HELP ME :( (Enta)
hi there
welcome to honda-tech......do some searching and you will find lots of information about light weight crank pullies just like the one you are thinking of installing.
my recommendation is NOT to install that thing. the original crank pulley has a rubber insert to absorb vibration and harmonics which can damage the oil pump and main bearings. unless you plan use the car for race only and plan to re-build the engine frequently then i would not install that thing.
good luck
Old Jan 6, 2007 | 12:32 PM
Enta's Avatar
Default Re: Lightweight pull crank HELP ME :( (non-VTEC)
Ok, I understand. But maybe should I to reduce weight oryginal crank pulley? Then, original crank lost a few weight, and original absorb vibes & harmonic will be ( in original crank ). Good idea?
Old Jan 6, 2007 | 02:37 PM
mmuller's Avatar
Mad Scientist
yeah you can get your stock pulley machined and balanced.
you can remove PS and AC and keep the dampener
Old Jan 6, 2007 | 06:29 PM
91SiZ6's Avatar
You won't gain anything noticable with a light weight crank pulley.
Old Jan 7, 2007 | 12:59 AM
Enta's Avatar
Sh*t. What you thinkin' about a c.p. N1 ? Someone have this crank?
Old Jan 8, 2007 | 09:01 AM
webrex's Avatar
i got one on my b18c rex, been driving it daliy and on weekends sometimes i take it on mountain roads an drive the **** out of it. had no prob.
Old Jan 8, 2007 | 11:04 AM
EJgsr's Avatar
Default Re: Lightweight pull crank HELP ME :( (webrex)
get a CTR pully its only like 60 - 100 bucks
i have a type-r and no problems yet.
as_fast_as_u
Aug 3, 2005 01:57 AM
redciviclx14
Jun 25, 2003 09:55 PM
dynomax27
Apr 20, 2003 12:13 AM
jt-sport
Mar 17, 2002 05:07 AM
