late clutch engagement..?
Old Oct 7, 2003 | 08:54 PM
self_made's Avatar
Default late clutch engagement..?
my friend installed a new clutch on his car, I believe its an action 6 puck sprung clutch. anyways, when we went for a test drive, the clutch engages all the way at the top, what can be causing this?
Old Oct 7, 2003 | 09:32 PM
dshreeve's Avatar
Default Re: late clutch engagement..? (VTECNLUDE)
It sounds to me like you need to adjust the clutch pedal...
Behind the pedal arm, you will find a threaded rod that connects to the master cylinder through the firewall. Loosen the nut and turn the threaded rod until your engagement is where you want it. (Don't forget to tighten the nut when you're done! )
Hope this helps,
dshreeve
Old Oct 7, 2003 | 11:08 PM
Integspeed21's Avatar
Default Re: late clutch engagement..? (dshreeve)
Is there anyway to adjust the pressure of the clutch pedal?
Old Oct 8, 2003 | 11:48 AM
WundedSaint's Avatar
pressure plate probably on too tight....18 ft lbs is the proper torque for those bolts
Old Oct 8, 2003 | 11:52 AM
self_made's Avatar
Default Re: late clutch engagement..? (WundedSaint)
they were torqued to those specs
muddmonky
Transmission & Drivetrain
Jul 18, 2012 10:51 AM
batboyvaj
Sep 28, 2007 09:17 AM
InitialJRift
Sep 13, 2006 10:43 AM
99h22ek
Aug 19, 2006 05:04 PM
integra pride
Oct 12, 2004 03:58 AM
