knocking noise from tranny
Old Jun 17, 2005 | 12:04 PM
91integraLSVTEC's Avatar
Default knocking noise from tranny
i hear knock knock knock noise coming from my j1 cable tranny. when i step on the clutch it goes away. there are times when it would be really loud. any idea what this problem could be? thanks in advance
Old Jun 18, 2005 | 12:38 AM
slimer007's Avatar
Default Re: knocking noise from tranny (91integraLSVTEC)
Could be the input shaft or throw out bearing. Pressure plate might have come loose. These are just thoughts. The only way to really be sure is to pull the tranny out.
Old Jul 27, 2005 | 08:39 PM
jbs's Avatar
jbs
Bump! From someone who may have experienced this in the past. Me and a buddy of mine are having the same problems on our ITR trannies. We first thought our AC compressors were going out but I found out today that when I get on the clutch, the knocking goes away.
Old Jul 27, 2005 | 10:11 PM
Jimmy's Avatar
Global Moderator
Pull the tranny as soon as you can and then look there from further inspection, did it just start on its own?? Maybe a hard launch and broke the counter shaft or main shaft?
Old Jul 27, 2005 | 11:10 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Jimmy)
This has happened to two transmisisons Ive had. Its happening now on my ITR transmission. I think the bearings need replacement.
Old Jul 29, 2005 | 02:25 PM
sir boostalot's Avatar
Default Re: (JDM_Ej)
What the hell is up with everyones clutch and a/c going out over the summer, i got problems in both of these departments.
phelpsj2
Jan 4, 2010 02:27 PM
CalhounBoi
Jun 11, 2007 10:33 PM
JDM SLICK
Feb 16, 2005 05:38 PM
JDM SLICK
Feb 15, 2005 11:17 PM
BoostedsiR
May 31, 2003 05:28 PM
