knock sensor help code 23
Old Jul 16, 2008 | 12:29 AM
thebleek's Avatar
Default knock sensor help code 23
so i swapped a y8 into my dx and everything is all good.. except code 23/
well i got the 2 wire circular plug, and plugged it in, and grounded the other wire.
code 23...
so i swapped the wires...
code 23...
yes i reset the ecu, anytime i go over 4000 the light comes on. seems a lil hesitant, but rev's up to 7000 no problem..
so how do i do the wires for the knock?? i just ran the ground to the metal behind my headlight..where ive grounded other things before
Old Jul 16, 2008 | 11:05 AM
vtecb18c's Avatar
Default Re: knock sensor help code 23 (thebleek)
is it an obd1 ecu? if so just run a chipped p28 it doesnt use the knock sensor
Old Jul 16, 2008 | 01:29 PM
thebleek's Avatar
Default Re: knock sensor help code 23 (vtecb18c)
OBD2a
Old Jul 17, 2008 | 01:59 AM
thebleek's Avatar
bump
can coaxial wire from a tv work? it says it needs shielded wire
Old Jul 30, 2008 | 08:20 PM
geebs's Avatar
the knock sensor is a one wire sensor..
i dunno if coaxial cable will work.. thats a good thought.
02spoon
Oct 17, 2010 09:48 AM
JBirch_97Prelude
May 27, 2007 01:03 PM
sQwiReL bOi
Aug 11, 2004 12:42 AM
speshuled619
Jul 26, 2002 10:23 AM
speshuled619
Jul 25, 2002 05:12 PM
